MPLAB X IDE - how to get started
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default MPLAB X IDE - how to get started
    Over the past days, I've been reading threads and googled around about MPLAB. So I installed MPLAB X v2.15.
    I found enough info to install PBP 2.60 and set it as THE compiler; I'm using a PICKit2.
    Following different tutorials, I created a project, set it up and this is where I'm stuck now.
    I think I must now "build" the project to be able to program it into the PIC. But when I do so, I get following warning:
    make: *** No targets. Stop.
    BUILD FAILED (exit value 2, total time: 78ms)
    What am I doing wrong?
    Is MPLAB the only tool to debug my code?
    Roger
    Default Re: MPLAB X IDE - how to get started
    Hi Roger,
    If you mean source level debugging using the PICKit2 then yes. As far as I know MPLAB is the only tool which allows you to use a hardware debugger to debug (step, step over, set break points etc) a PBP program at the source level.
    I'm sorry but I can't help you getting PBP going inside MPLAB, been there a couple of times only to leave dissapointed....
    I'm frustrated too....
    So what would be a "good" software debugger - any suggestions?
    Roger
    its pouring rain here today so I had another go a getting pbp3 to work in labx, put labx ver 2 on the laptop
    added the pbp2.6 and pbp3 tool chains and guess what . it works
    I can now source debug a pbp3 project (pic18's only)
    seems in previous attemps I created my source files in the wrong spot
    see attached
    I have happily been using the one built-in into Microcde Studio for quite some years.
    They also have a free version which works only on the 16F628A to let you have the feel.
    http://melabs.com/resources/win_ide.htm#Studio
    Anand
  1. Problem with MPLAB IDE v7.60
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 19th July 2011, 19:28
  2. A new MPLAB IDE
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 6th May 2011, 16:31
  3. Mplab x ide
    By fowardbias in forum Off Topic
    Last Post: - 3rd February 2011, 09:32
  4. PBP and MPLab IDE
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 29th May 2008, 15:09
  5. MPLab IDE Project
    By BRINGERofBACON in forum General
    Last Post: - 3rd May 2008, 13:09
