Hi Ryan,
Yes, I think we're all guilty of the above now and then ;-)I wrote that, or rather pieced it together when I should have been going to bed for the evening. It does have the typical “noob” mistakes of not turning the analog inputs off and setting TRIS for my output pins and probably a few more mistakes!
I have a bad habit of tackling this stuff right before bed, figuring I can get things off my mind before trying to sleep with ideas bouncing around in there. Then I start racing the clock and trip myself up. <snip>
That's the situation in my case as well. It can go months without me working on a particular project. However, what I do is visit this forum (and the MELABS forum (though it's pretty silent most of the time)) and trying to help other members with their issues, discuss implementation ideas etc. Doing that helps me remember what I've learned and learn a lot of new stuff.Another problem is that, as you can see by my forum join date, I’ve been using PicBasic Pro a few years now. But I only work on PIC based projects once every few months, sometimes longer. And as they say: if you don’t use it…
Not at all. Everything is hard (more or less) until you know how to do it. Interrupts are no different but Darrel has really made a BIG difference with the DT-INTS routines. It makes it really quite easy without the drawbacks of ON INTERRUPTS, though it does have it drawbacks which you'll also get familiar with over time.But that said I’ve done all sorts of complex projects with PicBasic Pro, from thermostats with one-wire sensors and LCD readouts to all kinds of PWM motor and lighting controllers, robots, etc. I’ve just always found ways around using scary interrupts and timers. But I guess that’s what separates the men from the boys.
Nothing wrong with SEROUT but you really "should" get up to speed with using HSEROUT, especially so now when you start introducing interrupts because once you do your SEROUT will basically stop working (if you don't see to it that an interrupt will NOT fire while the PIC is executing the SEROUT). I've got a couple of different development boards and they all got level translators (MAX232 etc) and/or a FTDI USB<->RS232 chip on them so I usually don't need to do anything special. When breadboarding (as I did with this code) I've got this thing which makes it really easy.I tend to use SEROUT over HSEROUT because it doesn’t require outside help to communicate directly with the serial port on my PC. And I did remember that when trying to run your code the first time and gibberish was appearing in hyperterminal .
I'm not sure I understand. You're polling the Measure flag but you're not polling the actual input(s). However, the way you have it written above it will first measure the time between the trig pulse and the first pulse. Then it will sit there and wait for the next trig pulse and THEN measure the time between THAT trig pulse and the second pulse. What you probably want to do is enable the CCP interrupts from the SixtyHz interrupt routine and (again probably) get rid of the Capture subroutine alltogether.Isn’t this the same as polling kind of sort of? Why would I want to do that? Am I even supposed to be doing that?! Does it really matter if CCP2 gets a read of the counter before CCP1? On and on…Code:Capture: Measure = 1 While Measure = 1 : WEND ' Wait until ISR has created the rising edge and started the timer @ INT_ENABLE CCP1_INT ; Start new capture Measure = 1 While Measure = 1 : WEND ' Wait until ISR has created the rising edge and started the timer @ INT_ENABLE CCP2_INT ; Start new capture RETURN
