OK, this version generates the 60Hz, 50% dutycycle in the background using TMR0 and DT-Ints.
Since we are generating the output I don't see the need to feed the signal back into the PIC to trig on.
Anyway, this compiles and runs on a 16F628 here on my breadboard. It generates the 60Hz output but I haven't actually fed any pulses back into it to see if the actual measurment code works. You'll have to do that yourself. Please note that since we're using interrupts in the background you can not use SEROUT to send the data since the interrupts will mess with the timing. Fortunately the 628/648 have an USART - use it with HSEROUT as in the code.
Let us know how it works out.
/Henrik.Code:DEFINE NO_CLRWDT 1 ' We need the prescaler for TMR0, can't use the WDT DEFINE OSC 20 ' Running with a 20MHz x-tal #CONFIG __config _HS_OSC & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF #ENDCONFIG ' Variables needed by DT-INTS (we miss you Darrel!) wsave VAR BYTE $70 SYSTEM wsave1 VAR BYTE $A0 SYSTEM wsave2 VAR BYTE $120 SYSTEM Time1 VAR WORD ' Time between leading edge of Pulse1 and leading edge of Pulse2 Time2 VAR WORD ' Time between leading edge of Pulse1 and leading edge of Pulse3 Temp VAR BYTE ' Temporary variable, use at will Measure VAR BIT ' Semaphore to indicate when we want to start a measurment. TrigOut VAR PortB.3 ' Pin for 60Hz output Pulse1 VAR PortB.4 ' Input pin for first pulse Pulse2 VAR PortB.5 ' Input pin for second pulse TMR1IF VAR PIR1.0 ' Alias to TMR1 interrupt request flag which we use for timeout feature. INCLUDE "DT_INTS-14.bas" INCLUDE "ReEnterPBP.bas" ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR0_INT, _ISR, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM OPTION_REG = %11000111 ' Prescaler assigned to TMR0, 1:256 ratio TRISB = %11110111 ' Set PortB direction. @ INT_ENABLE TMR0_INT ; Enable the 120Hz interrupt for the square wave generator. Main: Pause 1000 Gosub Capture IF TMR1IF THEN HSEROUT["Timeout before capturing both pulses.",13] ELSE HSEROUT["Time 1: ", DEC5 Time1, " ticks.",13] HSEROUT["Time 2: ", DEC5 Time2, " ticks.",13] ENDIF Goto Main '------------------------------------------------------------------------------- Capture: Measure = 1 While Measure = 1 : WEND ' Wait untill ISR have created the rising edge and started the timer '------------------------------------------------------------------------------- ' Now look for the rising edge of the two pulses we're expecting to recieve. ' Once we see the pulse we grab the TMR1 value and store it. ' If we don't get both pulses before the TMR1 overflows (as indicated by ' the TMR1 Interrupt Flag) we abort the operation. This happens after ' 200ns * 2^16 = ~13ms. DO ' Do we have a rising edge on Pulse1 input? ' Capture value ONLY if we haven't already done so. IF Pulse1 AND (Time1 = 0) THEN Time1.HighBYTE = TMR1H Time1.LowBYTE = TMR1L ' Make sure TMR1L didn't overflow inbetween reading the high and low byte Temp = TMR1H If Temp <> Time1.HIGHBYTE THEN Time1.HighBYTE = TMR1H Time1.LowBYTE = TMR1L ENDIF ENDIF '------------------------------------------------------------------------------- ' Do we have a rising edge on Pulse2 input? ' Capture value ONLY if we haven't already done so. IF Pulse2 AND (Time2 = 0) THEN Time2.HIGHBYTE = TMR1H Time2.LOWBYTE = TMR1H ' Make sure TMR1L didn't overflow inbetween reading the high and low byte Temp = TMR1H If Temp <> Time2.HIGHBYTE THEN Time2.HighBYTE = TMR1H Time2.LowBYTE = TMR1L ENDIF ENDIF LOOP UNTIL ((Time1 <> 0) AND (Time2 <> 0)) OR TMR1IF '------------------------------------------------------------------------------- RETURN '------------------------------------------------------------------------------- ISR: If TrigOut = 0 THEN ' If trig output is low.... If Measure = 1 THEN ' ...and we want to start a measurment T1CON.0 = 0 : TMR1IF = 0 ' Stop timer and clear interrupt flag TMR1H = 0 : TMR1L = 0 ' Clear the time Time1 = 0 : Time2 = 0 ' Clear measurements T1CON.0 = 1 ' And start the timer Measure = 0 ' Let main program know we've set the ball in motion. ENDIF TrigOut = 1 ' Set trig output high ELSE TrigOut = 0 ' Trig output was high, set it low. ENDIF TMR0 = TMR0 + 94 ' Reload TMR0 for 120Hz interrupt rate @ INT_RETURN '-------------------------------------------------------------------------------
