SD card does not initialize
Results 1 to 2 of 2
    Aug 2014
    Default SD card does not initialize
    i am running a simple code that is supposed to create a txt file on sd card and write a line in it. My code starts from initializing command. i checked the return value. and the card does not initialize. what do i do now??? what can be the possible reasons for this???
    please help.
    Just for information i am using 8gb sd card. if it has anything to do with it. My code now is as follows
    My code is as follows
    i checked the return value. and yes the card does not initialize. what do i do now??? what can be the possible reasons for this???
    please help.
    void delay (unsigned int k)
    for (i=0;i<=k;i++)
    void main(void)
    FSFILE *MyFile;
    unsigned char txt[ ]="This is a TEXT message";
    TRISB=0;
    // Initialize the SD card routines
    FSInit( );
    if (FSInit()!=TRUE)
    {PORTB=0xFF;
    delay(10000);
    PORTB=0x0;
    delay(10000);
    // Create a new file called MESSAGE.TXT
    MyFile = FSfopenpgm("MESSAGE.TXT", "w+");
    // Write message to the file
    FSfwrite(txt, 1, 22, MyFile);
    // Close the file
    FSfclose(MyFile);
    while(1);
    When i run the code, the portb leds blink. which means the sd card does not initialize.
    Default Re: SD card does not initialize
    This is "C". Maybe you should check one of those Arduino forums or Microchip forums depending on which processor you are using.
    EN82fn
  1. Do you have to initialize an on-Screen Display module?
    By Ramius in forum mel PIC BASIC Pro
    Last Post: - 28th April 2011, 01:53
  2. PortB pins will not initialize LOW, only HIGH?
    By ronbowalker in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 20:27
  3. Replies: 2
    Last Post: - 27th May 2008, 16:49
  4. HOW do you initialize PortC to normal I/O??
    By Len in forum mel PIC BASIC Pro
    Last Post: - 11th June 2005, 19:56
  5. SD-Card
    By glaubertadeu in forum General
    Last Post: - 27th April 2005, 15:57
