16F819 serin
Results 1 to 4 of 4
Thread: 16F819 serin
    Jun 2005
    Default 16F819 serin
    I am attempting to communicate between 2 pics. I can send data OK
    but cannot seem to receive the serial data in to the pic. I can read the data
    with a serial input lcd. I have only attempted to send a single byte 128 to 255. Have any suggestions?
    INCLUDE "modedefs.bas"
    DEFINE OSC 8
    DEFINE CHAR_PACING 500
    OSCcon = $70 ' config 8mhz
    SO CON 6 ' Define serial output pin.
    SI CON 1 ' Define serial input pin.
    F VAR BYTE
    Output PORTB.0 'FDOT Out
    Input PORTB.1 'Serial In
    Output PORTB.2 'C1 Relay
    Output PORTB.3 'PWM Output
    Input PORTB.4 'status LED
    Output PORTB.5 'H Relay
    Output PORTB.6 'Serial Out
    Output PORTB.7 'C2 Relay
    PB = $ff
    'TRISA = %11111111
    'TRISB = %00000011
    'Poke PORTB, %00000000 ' Initialize PortB
    'Poke PORTA, %00000000 ' Initialize PortA
    Pause 2000
    loop:
    SerIn SI,t9600,F ' input character
    SerOut SO,t9600,[I,148,#F]
    Pause 500
    GoTo loop
    electronicsuk's Avatar
    electronicsuk Guest
    Have you tried serin N9600 instead of T9600? When you receive directly from a computers serial port you need to use inverted (N), and a PC serial port sends out true, so I believe the same should be true for communication between two micros. You need to send in true and receive in inverted.
    Jun 2005
    Unhappy
    I have tried T9600, N9600, OT9600, ON9600.
    I tested the B1 input energizing a digital output and that works.
    I tried serin on B4 and it doesn't seem to work either.
    I'm stuck
    looks like a faulty one since RB4 is multiplexed with the MSSP and it's disable at start-up...
    On wich pin the other PIC send the data???
    RA.4??? If so is there any pull-up resistor attach to??
    any on PORTA??? if so, is all analog stuff are disable???
  1. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  2. serin question?
    By sachymo in forum General
    Last Post: - 27th July 2008, 11:04
  3. Serin Problem 16f819
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 23:50
  4. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
