I am attempting to communicate between 2 pics. I can send data OK
but cannot seem to receive the serial data in to the pic. I can read the data
with a serial input lcd. I have only attempted to send a single byte 128 to 255. Have any suggestions?
INCLUDE "modedefs.bas"
DEFINE OSC 8
DEFINE CHAR_PACING 500
OSCcon = $70 ' config 8mhz
SO CON 6 ' Define serial output pin.
SI CON 1 ' Define serial input pin.
F VAR BYTE
Output PORTB.0 'FDOT Out
Input PORTB.1 'Serial In
Output PORTB.2 'C1 Relay
Output PORTB.3 'PWM Output
Input PORTB.4 'status LED
Output PORTB.5 'H Relay
Output PORTB.6 'Serial Out
Output PORTB.7 'C2 Relay
PB = $ff
'TRISA = %11111111
'TRISB = %00000011
'Poke PORTB, %00000000 ' Initialize PortB
'Poke PORTA, %00000000 ' Initialize PortA
Pause 2000
loop:
SerIn SI,t9600,F ' input character
SerOut SO,t9600,[I,148,#F]
Pause 500
GoTo loop
