problem with serial com
Results 1 to 8 of 8
    Default Re: problem with serial com
    How are you handling MCLR?
    Oct 2009
    hello only with a button or a power cycle
    Quote Originally Posted by nono2002 View Post
    Try turning MCLRE to OFF in the configuration.
    What version of PBP are you using? It makes a difference on how you do it.
    Oct 2009
    i put mclre off but it's the same thing, my version of PBP is 2.60
    f I unplugged PICkit3 and I reset the prog runs it displays me the correct values ​​on the displays, given series are erroneous if I reconnect the PICkit3 reset this and the serial data is ok
    My best guess would be a grounding issue. Evidently you are powering the PIC independent from the PC. When the PicKit is connected it changes the potential on the zero rail (ground).
    Oct 2009
    thank you for directing me to the problem of mass it was indeed a mass between my converter and my plate 'I was thinking more of a problem config 18f thank you again
  1. serial problem
    By longsigh in forum mel PIC BASIC Pro
    Last Post: - 9th November 2010, 16:43
  2. serial communication problem
    By kindaichi in forum Serial
    Last Post: - 11th March 2010, 17:37
  3. Y A Serial problem
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2004, 05:40
  4. Replies: 8
    Last Post: - 11th November 2004, 21:08
  5. Serial communication problem
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 19th July 2004, 15:32
