Monitoring negative voltages
Results 1 to 3 of 3
    Default Re: Monitoring negative voltages
    Thank you Charles,
    This should prove helpful.
    Sep 2005
    Campbell, CA
    I should also add that - when converting voltages, you gain a lot of accuracy from oversampling.
    For example, if you need to multiply an A/D reading by 14, rather than take one sample and multiplying it by 14, take 14 samples and add them up. At 40Mhz, a single conversion takes only about 20uSec, so the oversampling doesn't add much overhead.
    http://en.wikipedia.org/wiki/Oversampling
    Charles Linquist
  1. Amicus18/Arduino/Whatever voltages
    By dhouston in forum PBP & Amicus18
    Last Post: - 6th June 2011, 14:14
  2. Current sensing at high voltages
    By jmgelba in forum Schematics
    Last Post: - 13th December 2010, 15:10
  3. Transducer's Voltages - what are they?
    Last Post: - 12th April 2008, 14:53
  4. Replies: 2
    Last Post: - 14th November 2007, 08:27
  5. Measuring negative voltages
    By sammy in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 02:36
