Hi there,
Using the HWPWM is not a big issue at all. All you have to do is set the correct registers and check for overflows through interrupt. To make your life easier there is a freeware by Doug McDonale called PIC HWPWM Calculator (I cannot remember the link now).
PBP makes your life easy and lets you concentrate on the program flow but it is always a good idea to keep yourself updated with the MPASM routines. Read your manual thoroughly.
Sougata
