Instant Interrupts for rotary encoder
Results 1 to 8 of 8
    Default Re: Instant Interrupts for rotary encoder
    That interesting but I repeat, int on A, on interupt read B, if it is c/w if 1 it is ac/w it is 0 (or the other way round). Caps on A and B to gnd, 10k pullup on A and B to Vcc. Bobs your uncle.
    Any contact bounce on A will be disrequarded because your interupt routine won't have reenabled ints yet and B will be read dead in the middle of its cycle.
    George
    I hadn't thought of disabling interrupts momentarily, excellent idea. A short timer could control the interval as well.
    My PIC was dedicated so I just looped and checked the state of the pins.
    Hi guys,
    I may be stating the obvious but if you trip the interrupt off of the rising edge of one channel you're effectively dividing the resolution of the encoder by 4. To get the full resolution you need to count all edges of the quadrature cycle.
    There are two types of encoders with detents typically used as front-panel controls. One have a full quadrature cycle per detent and using the "interrupt on rising edge of one channel" method can work with these but what you think might be noise on the signal could (and probably is) the second rising edge on the A-signal within the same quadrature cycle. The divide by 4 "issue" doesn't really apply here because you basically can't position the encoder between two detents. Another possible issue though is that when the encoder "clicks" from one detent to another a full quadrature cycle is output. If the interrupt latency is "highish" the firmware might not actually "catch" channel B quick enough. Catching it at the wrong time results in it counting the wrong way.
    The other type of encoder have one detent per quadrature state. Using the "interrupt on rising edge of one channel" method with this type will result in the software detecting every 4th click, skipping the other 3.
  1. New approach to Rotary Encoder
    By Ioannis in forum Code Examples
    Last Post: - 11th July 2013, 22:05
  2. Calculate Distance Using Rotary Encoder
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 4th May 2012, 17:40
  3. Rotary encoder help (not 'counting steps)
    By Elnino in forum mel PIC BASIC Pro
    Last Post: - 26th October 2009, 23:03
  4. Automotive quality rotary encoder
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 8th October 2004, 16:46
