frequency prescaler using PIC
Results 1 to 7 of 7
    France
    Default frequency prescaler using PIC
    hello
    I am not fluent to search on database, I try to reach some thead with the word "DIVIDER" or "frequency" without succes.
    my question is :
    Instead using a lot od 74LS390 dividers to have a 1 Hz output from a 10 Mhz oscillator
    I try to find a solution using a PIC.
    Is somebody has done such application ?
    this will be use in the GPS solution (1pps output) to synchroniqze a 10 Mhz VCXO
    thanks in advance
    Francois F1CHF
    Default Re: frequency prescaler using PIC
    try a search for PLL
    You can use a 32.768 KHz clock crystal on timer 0 to get 1 Hz timer interrupt. Darrel did this for someone recently for a frequency counter or tachometer project. Nice thing is code runs in hardware.
    EDIT: Found it
    http://www.picbasic.co.uk/forum/show...ht=#post125647
    France
    Thanks for your replies, I found some example using serach with "counter" and "frequency"
    I must explain now with more details
    I don't need to generate a 1hz signal
    I need to divide the signal from a 10 mhz VCXO(variable oscillator depending a control voltage)
    the well know solution is to use 4 IC like 74LS390 .. too big for me ...i term of placement
    That why I am looking for a newer system (example OCXO signal will become the PIC crystal and
    I must find "something" to count up to 10.000.000 pulses , I know that we are working with Words
    each time the word register is full, I will add 1 in a second register (up to 152 times) remaining
    is 38680 ....
    may be I am "outside my shoes ...." French expression ...
    this 1hz signal (from VCXO) will be compared with a GPS signal (called 1 pps) this GPS is one of
    the best reference to get the lowest PPM deviation
    output from the comparator will be injected to the VCXO, this is in fact a PLL system !
    all the PLL integrated circuits I know, don't have the internal divider up to 10 millions
    I know that I can put a prescaler between the OCXO to feed the PIC but if can avoid it
    it will be great !
    hope my "spannish writing" is enough clear
    Francois
    if you used a 16bit timer interrupt (say the timer is preloaded with (65536 -7 -10000 )) and its clock source the 10mhz osc that would give you a 1khz signal .
    if that was incremented into a word var and subtracted from 1000 on an edge signal of the pps you would then have a + or minus error signal .
    but how you could use that error to vary the vco is another story and would the resolution be fine enough ?
    a pair of CD 4059 ???
    ... ooooops....
    France
    hello
    I didn't answer to Richard, I must rere read the timer and interrupt story and make a test first ...
    for the CD4059 it's an idea !
    I have already said "the well know solution is to use 4 IC like 74LS390 .. too big for me ...i term of placement
    there is also an other way, using FPGA item ... I have a good contact to test this solution (not easy to understand)
    thanks
    Francois
  1. Maximum frequency output from a PIC
    By NickMu in forum General
    Last Post: - 5th December 2013, 21:38
  2. Changing PreScaler during interrupt
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 1st May 2008, 14:48
  3. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
  4. Replies: 2
    Last Post: - 10th February 2006, 02:04
  5. Frequency Counter using PIC and PicBasic
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 28th January 2005, 07:20
