An unintentional TRIAC triggering at start-up
Results 1 to 5 of 5
    Dec 2012
    Türkiye
    Default An unintentional TRIAC triggering at start-up
    Hi everyone ;
    I've been working on a dimmer circuit in order to use / dim an incandescent lamp . I'm using the same exact Triac Driver circuit below .. And here is my problem ,
    When I power up my circuit the lamp is triggered transiently , for a very short time ... (Like a flash effect) .. How can I prevent this happening to the lamp ?
    This happens when I only power up the TRIAC side of the circuit .. So it doesn't have anything to do with PIC MCU ...
    Any suggestions ?
    http://i.stack.imgur.com/puXQb.png
    Sep 2009
    Default Re: An unintentional TRIAC triggering at start-up
    Try to add RC snubber to triac.
    http://educypedia.karadimov.info/library/6785.pdf
    google snubber
    Set your "PORT" status to the intended state before you set the "TRIS" to output so it sets the output to a non fire state and then implements it.
    Dec 2012
    Türkiye
    the Snubber took care of it ... Thanks so much
  1. TRIAC triggering issues?
    By George in forum Off Topic
    Last Post: - 8th March 2012, 18:31
  2. Triggering the First UART TX Interrupt..How To?
    Last Post: - 17th November 2011, 00:54
  3. 500K or less triggering of a pin.
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 12th March 2009, 21:52
  4. False Triggering I/O
    By pdegior in forum mel PIC BASIC Pro
    Last Post: - 17th July 2005, 09:02
  5. Triggering 5 TTL clocks simultaneously
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 16th March 2005, 14:29
