RB0 / INT TRISB.0 configuration
Results 1 to 4 of 4
    Dec 2012
    Türkiye
    Default RB0 / INT TRISB.0 configuration
    Hi Everyone ;
    I've got a question digging my mind for a while .
    I've been reading the datasheet of 12F683 and 16F1827 to determine whether it is required to set or clear the TRISB.0 register to use the RB0 / INT pin for an interrupt purpose , I can't find any statement about it on the datasheet ...
    What do you guys think ? Should we set the TRISB.0 to use RB0 pin to activate the interrupt ? Or is it just sufficient to configure the INTCON=%10010000 ?
    Regards ..
    Default Re: RB0 / INT TRISB.0 configuration
    it hardly seems likely to be a good idea to try and drive a pin high or low when its set to be an output . if you want an external interrupt the chosen pin must be an input
    Even though the data sheet says POR is input I ALWAYS set in code.
    Dec 2012
    Türkiye
    Thank you guys so much ...
  1. TRISA, TRISB setting ?
    Last Post: - 10th January 2011, 20:32
  2. Using both hardware int and Timer Int together?
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 6th January 2010, 01:09
  3. Replies: 6
    Last Post: - 10th September 2008, 10:04
  4. INTCON (RB0/INT) and TRISB
    Last Post: - 7th September 2006, 20:38
  5. I would like to make some code tmr0 and int(RB0) interrupt
    Last Post: - 17th February 2006, 00:06
