better way to do this using math
Results 1 to 8 of 8
    Feb 2012
    PERTH AUSTRALIA
    Default better way to do this using math
    hi guys , have mind blank on how to best do this code in math than use a lookup
            if val < 6  AND Menu_Select = 211 then   lookup val,[0,2,4,8,16,32],val
            if val =>6  and val <= 11 and Menu_Select = 2112 then  lookup val-6,[0,2,4,8,16,32],val
            if val =>12 and Menu_Select = 2113 then lookup val-12,[0,2,4,8,16,32],val
    Feb 2012
    PERTH AUSTRALIA
    Default Re: better way to do this using math
    retry
            if val < 6  AND Menu_Select = 211 then   lookup val,[1,2,4,8,16,32],val
            if val =>6  and val <= 11 and Menu_Select = 2112 then  lookup val-6,[1,2,4,8,16,32],val
            if val =>12 and Menu_Select = 2113 then lookup val-12,[1,2,4,8,16,32],val
    May 2008
    Italy
    Power 2 to the value of val ( 2^val) and you will get the same value as your lookup table.
    Since 2^0 = 1 you will use an if then to turn it into zero.
    Cheers
    Al.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by longpole001 View Post
    retry
    Obviously I do not know how this code fits into your main program but here is an idea that could be of use.
    WHILE val > 5
    val = val - 6
    wend
    val = 1 << val
    I am not sure about this line "val = 1 << val " just try it is all I can suggest.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by EarlyBird2 View Post
    WHILE val > 5
    val = val - 6
    wend
    val = 1 << val
    Sheldon,
    I have tested this and it works a treat. It must save a lot of code space compared to your original three lines?
    Feb 2012
    PERTH AUSTRALIA
    the manual shows " ^ " to be a bitwise exclusive OR ?
    May 2008
    Italy
    Forgotten that PBP has not the power. Well you can use the shift left. Every shift you multiply by two so B1 = B0 << val where B0 = 1. Still need the filter to turn the one into zero, when val = 0.
    Cheers
    Al.
    Feb 2012
    PERTH AUSTRALIA
    yep i did not see an easy math "power " option , which would be good
    i am just trying to save code space a bit, lookups take more code space than math calc
  1. Help with A/D math!
    By dbodenheimer in forum mel PIC BASIC Pro
    Last Post: - 19th March 2011, 01:51
  2. Math help please...
    By Ioannis in forum General
    Last Post: - 20th June 2008, 11:18
  3. Math Help Please
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 21st May 2008, 20:00
  4. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  5. Math help please!!!
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 15:45
