Problem With 220 VAC Halogen Lamp Dimming
Results 1 to 8 of 8
    Jul 2008
    TURKIYE-KONYA
    Default Problem With 220 VAC Halogen Lamp Dimming
    I was using Pic based Zero Cross Detect dimmer Incandescent lamps with no problem.
    However; when i use halogen lamps instead of incandescent lamps, The dimmer circuit isn't working properly.
    So, what seems to be the problem? Any sudgestions?
    Regards..
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Problem With 220 VAC Halogen Lamp Dimming
    i would check the rating of the switching mosfet , as some halogen can have a higher load current at startup than incandescent lamps
    Jul 2008
    TURKIYE-KONYA
    I have used Opto-Triac and triac for dimming A.C halogen lamp.
    May 2008
    Italy
    You need to post the schematic and the code, if you want some real help.
    Cheers
    Al.
    Jun 2009
    Sc*nthorpe, UK
    Having looked into Halogen lamps I noticed that there are Dimmable versions and was wondering what can be the difference between standard Halogen lamps and dimmable Halogen lamps?
    Jul 2008
    TURKIYE-KONYA
    Cheers
    Al.
    Hi aratti,
    This is the test code that i have used always for many projects. The microcontroller is PIC16F876A. PORTB.0 is Zero Cross Detect Input. PORTB.7 is fire triac output.
        TRIAC       VAR PORTB.7
        TIMEX       VAR WORD
        TIMEX_L     VAR TIMEX.LOWBYTE
        TIMEX_H     VAR TIMEX.HIGHBYTE
        OUTPUT  TRIAC
        INPUT   PORTB.0
        TRISC   = 255
        TRISA   = %111111
        ADCON1  = 7
        T1CON = 0
        CCP1CON = %00001010
        TMR1L   = 0
        TMR1H   = 0
        OPTION_REG  = %11000000
        FLAG  = 0
        TIMEX = 9000
        CCPR1L      = TIMEX.LOWBYTE
        CCPR1H      = TIMEX.HIGHBYTE
        LOW TRIAC
        PAUSE 100
        INT_Handler   INT_INT  ,  INT_GEL_1,   ASM,  yes
        INT_Handler   CCP1_INT   ,  INT_GEL_2,   ASM,  yes
            ;INT_Handler   TMR0_INT  ,  TMR0INT,   ASM,  yes
        INT_CREATE
    @ INT_ENABLE  INT_INT
    @ INT_ENABLE  CCP1_INT
       MAIN :
        TIMEX = TIMEX + 1
        IF TIMEX >= 9600 THEN
            FLAG = 0
            low TRIAC
            FLAG = 1
        PAUSE 1
        GOTO MAIN
    INT_GEL_1
        BCF _TRIAC
        BSF T1CON,0
        INT_RETURN
    INT_GEL_2
        BTFSC _FLAG , 0
        BSF _TRIAC
        BCF T1CON , 0
        CLRF TMR1H
        CLRF TMR1L
        MOVF    _TIMEX_H , W
        MOVWF   CCPR1H
        MOVF    _TIMEX_L , W
        MOVWF   CCPR1L
        INT_RETURN
    I noticed a little funny thing while building a dimmer ...
    take care to the input port behaviour vs input ( TTL or ST ? ) AND the applied rectified voltage ...
    the zero detection can occur very, very late from what is expected ...
    scoping what happens is very interessing.
    I solved it using the falling edge detection and applying a small delay leading precisely to the very beginning of the rising edge - 'scope used here -.
    so, the zero detection is very precise.
    ( application is a 250W IR Lamp for heating my hens home ... )
    Jul 2008
    TURKIYE-KONYA
    Thanks Alain and other friends for your replies..
    The problem was solved with a small R-C snubber. Connected to A1 and A2 pins of Triac.
  1. PIC to AC 220 V switch
    By boban in forum Schematics
    Last Post: - 3rd April 2008, 19:38
  2. help w/ lamp dimming using Pic12f675
    By DUDONG in forum General
    Last Post: - 18th October 2007, 13:40
  3. need help with lamp dimming using Pic12f675
    By DUDONG in forum mel PIC BASIC
    Last Post: - 17th October 2007, 10:44
  4. Switchmode halogen transformer question
    By George in forum Off Topic
    Last Post: - 11th February 2007, 10:13
  5. 220 to 110 to 24 volts DC
    By Ron Marcus in forum Off Topic
    Last Post: - 18th October 2006, 17:15
