Questions?
Results 1 to 6 of 6
Thread: Questions?
    Feb 2005
    GREECE
    Arrow Questions?
    Hello boys and girls,
    I have some questions using 16f628a 16Mhz
    1) HSERIN 500,MAIN,[WAIT(A), STR SERDATA\17]
    I input the A(byte) variable dit per bit and after that I want to read a stream which begins with A.Where is the wrong?Writting WAIT (A) it expects the ascii A which is something stable.
    2) WHILE PORTA.3 = 1 AND PORTA.4 = 1
    PAUSE 2000
    If PORTA.2=1 then
    I = I + 1
    IF I > 8 THEN I = 1
    NICK1: WHILE PORTA.3 = 1
    SerData[i] = "1"
    GOSUB OUT
    PAUSE 500
    WEND
    WHILE PORTA.4 = 1
    SerData[i] = "0"
    GOSUB OUT
    PAUSE 500
    WEND
    GOTO NICK1
    WEND
    I have 3 buttons.WHILE PORTA.3 and PORTA.4 are pressed together the user can make some changes.If you press THE BUTTON of PORTA.2 you can move to the one of the 8 dot leds(i=1 to 8) and pressing button PORTA.3 or PORTA.4 you can display 1 or 0.
    My progaram is not working propertly but it is works.How can I do much more easier and smaller?
    Best regards
    Nikos Geronikolos
    HELLAS
    WAIT("A")
    CMCON=7 ' disable analog comparator
    use Select Case will do the job.
    MyButtons=PORTA
    SELECT CASE Mybutton
    Case
    etc
    You may find that SELECT CASE produces wonderfully readable listings for us programmers, the final compiled code it produces isn't particularly compact.
    Heaps of IF statements, although not particularly neat in listings, does however produce the most compact compiled code.
    Experiment one way, then the other and make your own mind up.
    Feb 2005
    GREECE
    Thanks mister_e & Melanie,
    I use SELECT CASE comands and it works much better.
    What about my first question?
    The A is a byte.It is the start byte,an address of the stream that follows.I can change the A(byte) variable dit per bit.
    What I want is while I have set the A after I want to read a stream which begins with A.
    but this is not working.
    If I change to WAIT("A") the pic search to read the A ASCII not the A that I have set manual.
    Please help me
    NIKOS
    HELLAS
    yup but for 500mSec. What about to try only that part without any timeout??? What about to add an optional end character???
    BTW, here's something to play with.
        DEFINE LOADER_USED 1  ' Using Bootloader
        DEFINE OSC 20         ' Using 20MHZ crystal
        DEFINE HSER_RCSTA 90h ' Enable USART, continuous receive
        DEFINE HSER_TXSTA 24h ' Enable transmit, BRGH=1
        DEFINE HSER_SPBRG 129 ' 9600 Bauds
        define HSER_CLOERR 1  ' Enable automatic alear overrun error
        StartByteChar   VAR	byte
        StringOfChar    VAR	Byte[10]
        Counter         var byte
        RecycleBin      var byte
        CLEAR ' set all variables to 0
    AskUser:
        hserout["Enter start byte character",13,10] '
        HSERIN [StartByteChar]                      ' wait user choice
    Start:
        Hserout["Waiting for start=",startbytechar,_
                " And 10 character string..........",13,10]
        hserin[WAIT(Startbytechar),STR stringofchar\10] ' wait Start character
                                                        ' and store 10 next
                                                        ' character in StringOfChar
        for counter=0 to 9                 '
            hserout[stringofchar[counter]] ' Display results
            next                           '
        While PIR1.5           ' Check RCIF => input buffer full??
              recyclebin=RCREG ' flush all results in a don't care variable
              wend             '
        RCSTA=0   ' simple way to clear all
        RCSTA=$90 ' possible errors
        pause 100 ' USART initialisation delay... value come from nowhere
        hserout[13,10,rep "*"\50,13,10] ' just to make it cute on screen
        goto askuser
    hope this help
    Feb 2005
    GREECE
    My friend mister_e,
    The start byte the user set it by pressing push buttons and you can see it to leds.
    So,
    A.0=LED1 ;0 OR 1
    A.1=LED2
    A.2=LED3
    A.3=LED4
    A.4=LED5
    A.5=LED6
    A.6=LED7
    A.7=LED8
    hserout[13,10,DEC A,13,10]
    By changing the A bit per bit I can see in my terminal the corect decimal A.
    When I try to send with my terminal the start bit A & the stream the pic does not recognize nothing.
    IF I have set A = 01010101 MANUAL the pic expect to read the start bit A = 55 HEX?
  1. Two quick (and elementary) questions.
    By scorpion990 in forum mel PIC BASIC Pro
    Last Post: - 27th June 2008, 00:03
  2. A few 12F683 questions
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 04:54
  3. Usart Questions
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 8th March 2008, 02:17
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. Hi Everyone! Some newbie questions :-)
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 23:24
