I try PAUSE 1000 and does'nt seem to pause program 1 seconds. Why?
Results 1 to 7 of 7
    Jan 2010
    Default I try PAUSE 1000 and does'nt seem to pause program 1 seconds. Why?
    For large amount of time, Pause does'nt seem to work well, the measured period is less than I expected.
    high Led
    For i = 1 to 30
    next i
    low Led
    for i = 1 to 30
    next i
    Above code produced about 1Hz on Led pin and not 1/6Hz!
    Miami, Florida USA
    Default Re: I try PAUSE 1000 and does'nt seem to pause program 1 seconds. Why?
    Quote Originally Posted by luxornet View Post
    high Led
    For i = 1 to 30
    next i
    low Led
    for i = 1 to 30
    next i
    You are pausing for 3 seconds instead of 1 second.
    Anonymous
    What's the oscillator frequency and have you used DEFINE OSC xx to inform the compiler OF that oscillator frequency?
    Jan 2010
    I tried with 8MHz resonator and DEFINE OSC 8.
    The LCD attached to PIC display data properly and all other thing work well.
    Somebody else tried large PAUSE?
    Yes, many many many times and never ever have I had an issue.
    Which chip?
    What version of PBP?
    Are you using the default CONFIG?
    Miami, Florida USA
    I didn't read the last sentence of your first post. Yes, besides DEFINE OSC 8, you might need to check on other registers related to the PIC frequency. Does your chip uses the OSCCON register? What chip are you using?
    Anonymous
    . . . and be sure your define is in ALL CAPITAL LETTERS as Henrik posted, lower case will not work.
  1. Pause command? (maximum number of seconds allowable?)
    Last Post: - 8th July 2010, 05:24
  2. Do I need a pause?
    By tazntex in forum Serial
    Last Post: - 29th August 2008, 04:32
  3. Pause
    By blue in forum General
    Last Post: - 29th December 2005, 14:24
  4. pause 0.5
    By detail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 11:32
  5. GOSUB to do a pause?
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 15:21
