RTC Clock - Resetting
Results 1 to 14 of 14
    Sep 2005
    Default RTC Clock - Resetting
    I am battling with a RTC Clock that keeps re-setting after I loose power. I have done a few things which has helped the RTC keep the time when the power is off.
    Please see code below:
    * When I program the PIC I first need to exclude this line of code:
    Shiftout IO, SCLK, LSBFIRST, [$8e, 128]
    * and then I Re-insert the line of code after I program the PIC for the first time then the RTC Clock runs if power is disconnected
    * I have also deleted the GoSub Gettime Routine after I also program the PIC for the First time that also seems to help as well
    Is there any other way of doing this without deleting the above?
    Any help would be greatly appreciated..;-)
    ' This will not affect normal program operation.
    Define LOADER_USED 1
    define OSC 20
    Include "MODEDEFS.BAS" ' Include Shiftin/out modes
    Define LCD_DREG PORTD ' Define LCD connections
    Define LCD_DBIT 0
    Define LCD_RSREG PORTA
    Define LCD_RSBIT 0
    Define LCD_EREG PORTA
    Define LCD_EBIT 1
    ' Alias pins
    RST Var PORTC.2
    IO Var PORTC.1
    SCLK Var PORTC.0
    ' Allocate variables
    rtcyear Var byte
    rtcday Var byte
    rtcmonth Var byte
    rtcdate Var byte
    rtchr Var byte
    rtcmin Var byte
    rtcsec Var byte
    rtccontrol Var byte
    Low RST ' Reset RTC
    Low SCLK
    ADCON1 = 7 ' PORTA and E digital
    'Shiftout IO, SCLK, LSBFIRST, [$8e, 0]
    rtcyear = $14
    rtcday = $04
    rtcmonth = $7
    rtcdate = $24
    rtchr = $07
    rtcmin = $57
    rtcsec = $00
    Gosub settime ' Set the time
    Goto mainloop ' Skip subroutines
    ' Subroutine to write time to RTC
    settime:
    RST = 1 ' Ready for transfer
    Shiftout IO, SCLK, LSBFIRST, [$8e, 0] ' Enable write
    RST = 0 ' Reset RTC
    ' Write all 8 RTC registers in burst mode
    Shiftout IO, SCLK, LSBFIRST, [$be, rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, 0]
    RST = 0 ' Reset RTC
    'Shiftout IO, SCLK, LSBFIRST, [$8e, 128]
    gettime:
    Shiftout IO, SCLK, LSBFIRST, [$bf] ' Read all 8 RTC registers in burst mode
    Shiftin IO, SCLK, LSBPRE, [rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, rtccontrol]
    RST = 0 ' Reset RTC
    ' Main program loop - in this case, it only updates the LCD with the time
    mainloop:
    Gosub gettime ' Read the time from the RTC
    ' Display time on LCD
    Lcdout $fe, 1, hex2 rtcmonth, "/", hex2 rtcdate, "/" , hex2 rtcyear," "
    Lcdout $fe,$C0, hex2 rtchr, ":", hex2 rtcmin, ":", hex2 rtcsec
    Pause 30 ' Do it about 3 times a second
    Goto mainloop
    Default Re: RTC Clock - Resetting
    some rtc's power on reset to a set value eg ds1307 power on default is 01/01/00 01 .
    you can look for this value when your pic powers up and if its something else then assume the time is still set and leave it as it is.
    extract from the ds1307 data sheet
    On first application of power to the device the time and date registers are typically reset to 01/01/00 01 00:00:00 (MM/DD/YY DOW HH:MM:SS). The CH bit in the seconds register will be set to a 1.
    Nov 2007
    West Covina, CA
    Are you using a battery backup on the RTC that is isolated from the rest of the power supply?
    Louie
    Sep 2005
    Hi Louie,
    Yes I am connecting as per the datasheet, I am using a DS1302
    gavo
    Sep 2005
    Hi Richard,
    I seem to be doing everything correct, I even had MAXIM have a look at what I was doing, and they said it all looked good, that is why I am at such a loss having to program the device twice
    gavo
    the 1302 seems to have no defined por register settings, so why not write a couple of bytes to the rtc's ram when you set the time . on subsequent pic boot ups check the rtc ram for those bytes , if they are not set then run your settime code
    Nov 2007
    West Covina, CA
    I noticed you have "rtccontrol Var byte" but no value assigned to it, then used in the "gettime" sub-routine.
    What is supposed to happen there?
    I would also suggest using a button input to jump to "settime" so you only have to program once and just push the button to set the time while its running.
    mainloop:
    IF !switch THEN GOSUB settime
    Goto mainloop
    And add a While/Wend for the switch so it waits before going back or else it'll be continuously setting the time until you release the button.
    settime:
    RST = 0 ' Reset RTC
    RST = 0 ' Reset RTC
    WHILE !switch: WEND   ' Wait until button is released
    Louie
    Jun 2009
    Sc*nthorpe, UK
    When a RTC is installed with battery backup the time only needs setting once. There are no routines within your code to utilise the settime: and by including the line
    Shiftout IO, SCLK, LSBFIRST, [$8e, 128] writes are disabled.
    Could I suggest you have two programs one to set the initial time which includes the settime:, without Shiftout IO, SCLK, LSBFIRST, [$8e, 128] line and a second program that does not include settime:.
    You are stuck with a two stage programing process but the second program will not include the unused settime: code.
    There are other alternatives as others have suggested one would be to read the date from the RTC and compare to the initial settings. What are the readings from the RTC before any time is set? Is the default reading on power up 01/01/00 for example. If so then simply test for the year being 00 and if it is set the time else skip over it.
    Let me know what the default power up readings are and then I can help with the code.
    Sep 2005
    Hi Steve,
    My apologies for the delay
    Default Clock is:
    01:01:00
    00:00:80
    Clock does not move
    Gavin
    Jun 2009
    Sc*nthorpe, UK
    Gavin,
    Gosub gettime before settime. Then if year =00 then settime also remove the disableing line "Shiftout IO, SCLK, LSBFIRST, [$8e, 128] "
    Gavin, didn't we solve that issue?
    Sep 2005
    Yes we did, I was seeing if I could do a "one time" programming instead of 2, the rest is working 100%
    Gavin
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by gavo View Post
    Gavin
    Is the one time programing working?
    Need more help?
    Steve gave you the idea. Check the default of the DS1302 and then decide to setup or continue the normal program flow.
  1. Resetting a timer in VB6
    By Bruce in forum Off Topic
    Last Post: - 26th December 2013, 20:02
  2. PIC18F2220 I2C resetting
    By cpayne in forum mel PIC BASIC Pro
    Last Post: - 18th October 2010, 23:09
  3. PIC keeps resetting when executing subroutine
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 27th August 2009, 07:03
  4. PIC chip resetting. Very weird
    Last Post: - 28th October 2007, 17:07
  5. Pic resetting
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 1st January 2007, 21:00
