Cheap programmer with modern low voltage PIC support?
Results 1 to 8 of 8
    Default Cheap programmer with modern low voltage PIC support?
    Hello.
    I have DIY K-149 USB programmer, which is great, but can't support low voltage PICs, such as 16F887 or 16F1503. I need a cheap programmer that can support these chips and allow fuse config (pickit 3 does not allow).
    Any ideas?
    Default Re: Cheap programmer with modern low voltage PIC support?
    Pickit2 clone or the real thing. The clone is considerable cheaper.
    I have genuine Pickit 2. It does not allows to set fuses in the meaningful way.
    Oct 2011
    Pennsylvania
    Hello CuriousOne:
    I would like to clarify the question: Low voltage chips, meaning LF version(3.3V max Vdd) or low voltage programmable chips which do not use the usual 14V reset on MCLR to go into programming mode? Although I always include the __config setup into the program, I recall that I did config setup changes with PICkit2 standalone programmer just before the program was loaded. This even works when you use the MPLAB just to load the HEX file into the chip, quite a few clicks though. I use PICkit3 in case of 12LF1840 which my PICkit 2 does not support. By the way does anyone know where the upgrade for extended chip list can be downloaded for standalone PICkit 2 like the PIC LF chips? There are references that this exists but I cannot seem to find it.
    Thanks.
    I meant the newer chips, like 16F1507.
    For the Pickit 2, you can change the config, but it is in the way like address, byte, you have to remember that say at 93H is TRISIO config stored and so on. While the MicroBRN (The software that comes with K-149 programmer, has the direct checkboxes, so you can config MCLR, OSC, etc, etc in direct way).
    Why use a programmer to set fuses? Life is much easier if you set the fuses in the source of your program. Thus avoiding mistakes and making it much easier to revisit a project without having to remember what fuses you set.
    George
  1. All PIC pins outputting low voltage
    Last Post: - 1st July 2010, 14:31
  2. Using PIC as a Low Voltage Meter, need help
    By doable in forum General
    Last Post: - 27th June 2008, 18:41
  3. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 20:20
  4. Low voltage Pic
    By ruijc in forum General
    Last Post: - 23rd January 2008, 17:45
  5. Serin with low voltage
    By f_lez in forum General
    Last Post: - 21st August 2006, 12:52
