P1c18f26k20-internal clock set up fail -64mhz
Results 1 to 17 of 17
    Default Re: P1c18f26k20-internal clock set up fail -64mhz
    when attaching portb to the 74hc595 - then 1 of the port pin lost power.
    I'm not really sure what this means , its rather ambiguous
    perhaps a schematic diagram (or a photo) of your setup would be in order
    Apr 2008
    HI,,
    thANKS A LOT RICHARD,
    I MOVE TO USE 18F4620, THE PREVIOUS CONF. IS FINE (internal osc*4 = 32 mhz)
    the program runs well @40mhz (external osc) then there are problems
    i.e. data output randomly- (due to dirty breadboard)
    line appears on the screen (same cause above).
    i will going back to see the 18f26k20.next week.
    thanks again
    regards
    As requested by others, post your complete code and a schematic of your circuit.
    Have you disabled analog features on any pins you use as digital?
    Apr 2008
    HI ALL
    THANKS for all
    the program actually runs well, but the pause time is not correct and the current supply is not adequate ( due to dirty breadboar...)
    at high frequency, some of the port pins is measured = 0, (when the port drives other ic) look like there is no power at all.
    the set up is right:
    _FOSC_INTIO67_1H
    OSCTUNE = $40
    OSCCON = $70
    the PBADEN = OFF, so the portb is digital I/O
    thanks a gain for all
    regards
  1. 18F26K22 - Unable to get 64MHz Internal clock speed
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 16th July 2014, 16:53
  2. How to set the internal CPU speed?
    Last Post: - 26th April 2011, 20:04
  3. UberNewbie can't set his clock...
    Last Post: - 7th January 2009, 04:22
  4. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 17:44
  5. How to set internal oscillator on 16F88
    By newgeppetto in forum Off Topic
    Last Post: - 3rd December 2005, 09:28
