P1c18f26k20-internal clock set up fail -64mhz
Results 1 to 17 of 17
    Apr 2008
    Angry P1c18f26k20-internal clock set up fail -64mhz
    HI,
    I TRY to set up to run the osc internal @64Mhz, but fail.
    conf_1H: FOSC_INTIO67 (or FOSC_INTIO7) ;OTHER config's of 1H are off
    OSCCON = $70 (16MHZ selected)
    OSCTUNE = $40 (enable PLL)
    the output @portb.6 fail (no power)-and data out from other pins runs fast
    OSCTUNE =$40 {omitted)
    data out from portb runs well, but slow and low power @ output
    i also try to set OSCTUNE TO $CF, maximum frequency and PLL enable, but portb.6 still lost power
    so what wrong?
    any help i do appriciate
    tks in ad.
    Default Re: P1c18f26k20-internal clock set up fail -64mhz
    try osccon.1 =1
    failing that post your code and tell us what version of pbp you are using
    Jun 2009
    Sc*nthorpe, UK
    This could help.
    OSCCON 6:4 need setting for 16 MHZ which is $70, which is what you have.
    OSCTUNE 6 needs setting to connect internal oscillator to 4xPLL $40, which you have.
    Looking at the Internal Oscillator Block OSCCON 1:0 have an effect and from the datasheet.
    bit 1-0 SCS<1:0>: System Clock Select bits
    1x = Internal oscillator block
    01 = Secondary (Timer1) oscillator
    00 = Primary clock (determined by CONFIG1H[FOSC<3:0>]).
    which tells me, if I understand correctly, that OSCCON 1 needs setting. Which is what Richard said.
    Which now makes OSCCON $72.
    Last there is config1H for HSPLL and HFINTOSC/PLL
    _FOSC_HSPLL_1H EQU H'F6' ; HS oscillator, PLL enabled (Clock Frequency = 4 x FOSC1)
    _FOSC_INTIO67_1H EQU H'F8' ; Internal oscillator block, port function on RA6 and RA7
    _FOSC_INTIO7_1H EQU H'F9' ; Internal oscillator block, CLKOUT function on RA6, port function on RA7
    which I leave to you or others to explain, I use boot loader and never used configs.
    Apr 2008
    Angry Re: P1c18f26k20-internal clock set up fail -64mhz
    THANSKS alot for your help.
    yes, i try
    OSCCON = $72,
    OSCTUNE = $40
    the problem still persises.
    portb.6 lost power. but it runs faster
    here is the conf.
    __CONFIG _CONFIG1H, _FOSC_INTIO7_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    __CONFIG _CONFIG2H, _WDTEN_ON_2H & _WDTPS_512_2H' __CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _HFOFST_ON_3H & _MCLRE_ON_3H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    OSCCON = $72,
    OSCTUNE = $40
    portb = 0
    latb = 0
    trisb = 0
    about the SCS it is automatic set to 00- becasue in the CONFI_1h --- FOSC_INRIO67- (IT IS determined by primary osc in the 1H line)
    here is the explaination in the data sheet
    2.9.1 SYSTEM CLOCK SELECT
    (SCS<1:0>) BITS
    The System Clock Select (SCS<1:0>) bits of the
    OSCCON register select the system clock source that
    is used for the CPU and peripherals.
    • When SCS<1:0> = 00, the system clock source is
    determined by configuration of the FOSC<2:0>
    bits in the CONFIG1H Configuration register.
    • When SCS<1:0> = 10, the system clock source is
    chosen by the internal oscillator frequency
    selected by the INTSRC bit of the OSCTUNE
    register and the IRCF<2:0> bits of the OSCCON
    register.
    • When SCS<1:0> = 01, the system clock source is
    the 32.768 kHz secondary oscillator shared with
    Timer1.
    After a Reset, the SCS<1:0> bits of the OSCCON
    register are always cleared.
    the version, of pbp. it is 2.6c
    i read the post of: http://www.microchip.com/forums/m730158.aspx-
    also mentioned the same issue- but the PLLCFG is not recognized in the PBP
    thanks for your concern,
    regards
    try a __CONFIG _CONFIG4L, _DEBUG_OFF in your configs
    as henrik wrote yesterday in a similar post the config option's syntax can be found in the pic18f26k20.inc file in your relevant version mpasm directory
    interestingly there is a PLLCFG = ON in the pbp3 device reference config options
    look like a _PLLCFG_ON_1H is what you need
    Apr 2008
    HELLO,
    thanks for your guide,
    YES i try & _DEBUG_OFF_4L
    OSCCON = $72 (OR $70)
    OSCTUNE = $40
    PROBLEM PERSIS (slow)
    i will see the inc directory of mpas
    is it effected by the hc595?
    i found that its max freq. is 25MHz
    however, i test the 595 runs well @40mhz
    thanks a gain for your contribution
    regards
    Jun 2009
    Sc*nthorpe, UK
    Very interesting thanks.
    Yes one of the settings that worked in the above link is.
    __CONFIG _CONFIG1H, _FOSC_INTIO67_1H
    OSCCON = $70
    OSCTUNE = $40
    Is that not what you started with?
    Apr 2008
    Y]hello,
    yes the above is work.
    osccon = $70 or (60)
    osctune = $40
    for single leds
    i move to drive 595 then there r problem- lost power or low speed @ out put
    now i try to clean the pbp to see waht happen'
    thenak for your help.
    regards
    Apr 2008
    HI ALL,
    the pic run well @ 4mhz ,HSPLL; 8, 10mhz ... problem (HSPLL).
    the conf. remains unchanged
    __CONFIG _CONFIG1H, _FOSC_HSPLL_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    where is the problem?
    thanks all for your help
    regards
    minhle
    quite a lot here seems to be lost in the translation somehow
    what does this mean ?
    have you now changed to using an external xtal ?
    what is a 595 ? do you mean a 74hc595 ?
    if so a "595" can clock in data @100mhz which will be at least 10x greater than a bit banged routine could achieve even at 64mhz clock
    can I suggest you just try to "blink a led" on say portb.6 and see if it blinks at the correct rate , if not then post your complete code for further evaluation
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by MINHLE View Post
    regards
    The conf. has changed from #4
    here is the conf.
    osctune = $40
    for single leds
    If it works for single leds then it works and all of your code needs checking. So please post your code so we can help.
    Apr 2008
    HI,
    thanks for your help.
    i suspect st wrong,
    i test the whole port b. it runs well (8 leds) - FOSC_INTIO67 (16x4mhz)
    However, when attaching portb to the 74hc595 - then 1 of the port pin lost power.
    just last week, the system run well @40mhz. (external osc).
    now problem is data to send out is not right
    i will spend 1 more time to check, and will send the program to you
    regards
    I'm not really sure what this means , its rather ambiguous
    perhaps a schematic diagram (or a photo) of your setup would be in order
    Apr 2008
    HI,,
    thANKS A LOT RICHARD,
    I MOVE TO USE 18F4620, THE PREVIOUS CONF. IS FINE (internal osc*4 = 32 mhz)
    the program runs well @40mhz (external osc) then there are problems
    i.e. data output randomly- (due to dirty breadboard)
    line appears on the screen (same cause above).
    i will going back to see the 18f26k20.next week.
    thanks again
    regards
    As requested by others, post your complete code and a schematic of your circuit.
    Have you disabled analog features on any pins you use as digital?
    Apr 2008
    HI ALL
    THANKS for all
    the program actually runs well, but the pause time is not correct and the current supply is not adequate ( due to dirty breadboar...)
    at high frequency, some of the port pins is measured = 0, (when the port drives other ic) look like there is no power at all.
    the set up is right:
    _FOSC_INTIO67_1H
    OSCTUNE = $40
    OSCCON = $70
    the PBADEN = OFF, so the portb is digital I/O
    thanks a gain for all
    regards
  1. 18F26K22 - Unable to get 64MHz Internal clock speed
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 16th July 2014, 17:53
  2. How to set the internal CPU speed?
    Last Post: - 26th April 2011, 21:04
  3. UberNewbie can't set his clock...
    Last Post: - 7th January 2009, 05:22
  4. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  5. How to set internal oscillator on 16F88
    By newgeppetto in forum Off Topic
    Last Post: - 3rd December 2005, 10:28
