USB Learning
Results 1 to 20 of 20
Thread: USB Learning
    Default Re: USB Learning
    Please disregard my last post.
    From forum search there appear to be several examples of working keyboard descriptors. For example http://www.picbasic.co.uk/forum/showthread.php?t=2872 post #2
    Greetings guys,
    @ towlerg,
    I did checked them...in fact, the descriptor i'm using is the one from the link you posted...but like i said...they dont compile
    @pedja089,
    Thanks alot for the files. I opened the main file and just tried to compile...no success
    I get alot of errors when compiling....
    I'm very confused !!!
    These should compile...why cant i compile ??
    Rui
    Sep 2009
    Add DT_INTS-18 files.
    http://darreltaylor.com/DT_INTS-18/home.html
    I downloaded that example few years ago from forum, and I'm sure that it worked with PBP2.50.
    Hi pedja089,
    you are right...it did compile fine thanks...
    However...it's not being recognized with windows XP
    Damn...i have no luck with USB stuff !!!!
    If i code the pbp demo it recognizes, this one does not...
    Sep 2009
    You probably need to set fuses according to your board...
    EDIT:
    Copy fuses from demo to keyboard...
    Did that didnt worked
    Well,
    after burning my eyes out until now trying to get this thing working i'm just about to give up !!!!
    I made some small changes to my main code and tryed many descriptors and configurations.
    All descriptors in this forum, or dont compile, or are not accepted by the PC, etc.
    I was able to modify some so that they would compile and accept by the PC as keyboard but i got strange results...
    With the same main code, some descriptors jam my PC keyboard inputs like one of the keys got stucked ( mostly control key or Alt Gr ). Disconnecting the circuit dos not solve...only a restart.
    I also noticed that if i changed the value from "usage minimum" retlw 0x19/retlw 0xE0 to retlw 0x19/retlw 0x04 i stopped getting the key stucked simptom.
    Weird is that most keyboard descriptor examples use E0 value
    Anyway...
    With the 04 value, when turning the circuit on i get a group of characters non stop "cdefh".
    A second descriptor with also the 04 value sends out "CDEH37W*" non stop.
    They both send characters even without any button being pressed...and with button pressed the output has the same characters.
    Again, here are both main code and descriptor
    '*  Name    : HID_USB_Keypad.BAS                                *
    '*  Author  : Peter MacLeod                                     *
    '*  Date    : 01/30/2011                                        *
    '*  Version : 1.01                                              *
    '@ CONFIG PLLDIV = 12		;1=4MHz, 2=8MHz, 3=12MHz, 4=16MHz, 5=20MHz, 6=24MHz, 10=40MHz, 12=48MHz
    '@ CONFIG FOSC = ECIO_EC		;XT_XT, XTPLL_XT, HS, HSPLL_HS, ECIO_EC
    @   __CONFIG   _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @   __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
    '@ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    '@ __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    'OSCTUNE.6 = 1		' Enable PLL for 18F87J50 family
    DEFINE OSC 48
    INCLUDE "KYPD_DESC.pbp"
    'include "KBDDESC.pbp"
    'include "DESCUSBProject.bas"
    'include "KBDDESCMOJA.bas"
    'DEFINE LOADER_USED 1
    'DEFINE RESET_ORG        1100h
    'DEFINE INTERRUPT_ORG    1108h
    'ASM
    'INT_LIST  macro		; IntSource,       Label,       Type,  ResetFlag?
    '        INT_Handler   USB_INT,  _SERVICE_USB,       ASM,  yes
    '        ;INT_Handler   RBC_INT,  _SERVICE_KYPD,      PBP,  yes
    '    endm
    '    INT_CREATE		; Creates the interrupt processor
    'ENDASM
    ' System Settings
    i						VAR BYTE
    BufferOut				Var Byte[8]
    ADCON1 = 15				' Set all I/Os to Digital
    INTCON2.7 = 1			' Disable PortB Pullups
    CMCON = 7				' Disable Comparators
    ' Keypad Settings
    TRISB = %01111111       'Set PORTB as inputs for keypad
    Keypad_Debounce			CON 60
    KeyPress                   VAR BYTE
    KeyPress_Old            VAR BYTE
    Keypad_Prev             VAR PORTB.0
    Keypad_Next             VAR PORTB.1
    Keypad_Play             VAR PORTB.2
    Keypad_Stop             VAR PORTB.3
    Keypad_Eject            VAR PORTB.4
    Keypad_Mute             VAR PORTB.5
    Keypad_VolUp            VAR PORTB.6
    led                             VAR PORTB.7
    Keypress = 0
    'KeyPress_Old = 0
    'START USB AND INTERRUPTS
    PAUSE 500              'TIME TO SETTLE
    USBINIT                'INITIALIZE USB
    USBSERVICE             'SERVICE USB
    'UIE = $7F              'ENABLE USB INTERRUPTS
    'UEIE = $9F             'ENABLE USB ERROR INTERRUPTS
    '@ INT_ENABLE  USB_INT
    ;@ INT_ENABLE  RBC_INT
    	BufferOut[0] = 0
    	BufferOut[1] = 0
    	BufferOut[2] = 0
            BufferOut[3] = 0
            BufferOut[4] = 0
    	BufferOut[5] = 0
    	BufferOut[6] = 0
            BufferOut[7] = 0
        low led
        high led
        pause 2500
        low led
    ' Main Subroutine
    if Keypad_Prev=1 then
    	BufferOut[0] = 0
    	BufferOut[1] = 0
    	BufferOut[2] = $15
        BufferOut[3] = 0
    	BufferOut[0] = 0
    	BufferOut[1] = 0
    	BufferOut[2] = 0
        BufferOut[3] = 0
    gosub SERVICE_USB
    GOSUB DoUSBOut
    GOTO Main
    ' Transmit data on the USB bus
    DoUSBOut:
        USBService
        USBOut 1, BufferOut, 8, DoUSBOut
    SERVICE_USB:
        USBSERVICE
    '@ INT_RETURN
    '*  Name    : KYPD_DESC.BAS                                     *
    '*  Date    : 25/07/2014                                        *
    '*  Version : 1.01                                              *
    '*  Notes   : USB HID CNC Keypad Descriptor                     *
    'USBMEMORYADDRESS Con	$400	' USB RAM starts here (set in device header file)
    USBMEMORYSIZE	Con	256	' USB RAM size in bytes
    USBReservedMemory Var Byte[USBMEMORYSIZE] USBMEMORYADDRESS	' Reserve memory used by USB assembler code
        Goto	kypd_desc_end	' Skip over all of the USB assembler code
        Asm
    #define USB_EP0_BUFF_SIZE	8	; 8, 16, 32, or 64
    #define USB_MAX_NUM_INT		1
    #define USB_MAX_EP_NUMBER	1
    #define NUM_CONFIGURATIONS	1
    #define NUM_INTERFACES		1
    #define UCFG_VAL	USB_PULLUP_ENABLE|USB_INTERNAL_TRANSCEIVER|USB_FULL_SPEED|USB_PING_PONG__NO_PING_PONG
    #define USB_POLLING
    #define HID_INTF_ID		    0x00
    #define HID_EP			    1
    #define HID_INT_OUT_EP_SIZE	1
    #define HID_INT_IN_EP_SIZE	1
    #define HID_NUM_OF_DSC		1
        include	"usb_hid.asm"	; Include rest of USB files, starting with HID class code
    DeviceDescriptor
    	retlw	(EndDeviceDescriptor-DeviceDescriptor)/2     ; Length of this descriptor
    	retlw	USB_DESCRIPTOR_DEVICE	           ; DEVICE descriptor type
    	retlw	0x10	                           ; USB Spec Release Number (low)
    	retlw	0x01		                       ; (high)
    	retlw	0x00		                       ; Class Code
    	retlw	0x00		                       ; Subclass code
    	retlw	0x00		                       ; Protocol code
    	retlw	USB_EP0_BUFF_SIZE                  ; Max packet size for EP0
    	retlw	0x81		                       ; Vendor ID  (low byte)
    	retlw	0x17		                       ;            (high byte)
    	retlw	0xD1		                       ; Product ID (low byte)
    	retlw	0x07		                       ;            (high byte)
    	;retlw	0x6F		                       ; Product ID (low byte)
    	;retlw	0x09		                       ;            (high byte)
    	retlw	0x01		                       ; Device release number (low)
    	retlw	0x00		                       ; (high)
    	retlw	0x01		                       ; Manufacturer string index
    	retlw	0x02		                       ; Product string index
    	retlw	0x00		                       ; Device serial number string index
    	retlw	NUM_CONFIGURATIONS                 ; Number of possible configurations
    EndDeviceDescriptor
    USB_CD_Ptr
    Configs
    	db	low Config1, high Config1
    	db	upper Config1, 0
    Config1
    	retlw	(Interface1-Config1)/2               ; Size of this descriptor in bytes
    	retlw	USB_DESCRIPTOR_CONFIGURATION         ; CONFIGURATION descriptor type
    Config1Len
    	retlw	low ((EndConfig1 - Config1)/2)       ; Length of this configuration (low)
    	retlw	high ((EndConfig1 - Config1)/2)      ; (high)
    	retlw	NUM_INTERFACES                       ; Number of interfaces in this cfg
    	retlw	0x01                                 ; Index value of this configuration
    	retlw	0x00                                 ; Configuration string index
    	retlw	_DEFAULT|_SELF	                     ; Attributes - bus powered
    	retlw	0x32                                 ; Max power consumption (2X mA)
    Interface1
    	retlw	(HIDDescriptor1-Interface1)/2        ; Size of this descriptor in bytes
    	retlw	USB_DESCRIPTOR_INTERFACE             ; INTERFACE descriptor type
    	retlw	0x00                                 ; Interface Number
    	retlw	0x00                                 ; Alternate Setting Number
    	retlw	0x01                                 ; Number of endpoints in this interface
    	retlw	HID_INTF                             ; Class code
    	retlw	BOOT_INTF_SUBCLASS                   ; Subclass code
    	retlw	0x00                                 ; Interface string index
    HIDDescriptor1
    	retlw	(Endpoint1In-HIDDescriptor1)/2       ; Size of this descriptor in bytes
    	retlw	DSC_HID                              ; HID descriptor type
    	retlw	0x11                                 ; HID Spec Release Number in BCD format - 1.11 (low byte)
    	retlw	0x01                                 ; (high byte)
    	retlw	0x00                                 ; Country Code (0x00 for Not supported)
    	retlw	HID_NUM_OF_DSC                       ; Number of class descriptors
    	retlw	DSC_RPT                              ; Report descriptor type (HID)
    ReportDescriptor1Len
    	retlw	low ((EndReportDescriptor1-ReportDescriptor1)/2)
    	retlw	high ((EndReportDescriptor1-ReportDescriptor1)/2)
    Endpoint1In
    	retlw	(EndConfig1-Endpoint1In)/2           ; length of descriptor
    	retlw	USB_DESCRIPTOR_ENDPOINT              ; ENDPOINT descriptor type
    	retlw	HID_EP|_EP_IN                        ; EP1, In
    	retlw	_INT		                         ; Interrupt
    	retlw	low (HID_INT_IN_EP_SIZE)             ; This should be the size of the endpoint buffer
    	retlw	high (HID_INT_IN_EP_SIZE)
    	retlw	0x0A                                 ; polling interval (10ms)
    EndConfig1
    ReportDescriptor1
        retlw   0x05
    	retlw   0x01    ; usage page (generic desktop)
    	retlw   0x09
    	retlw   0x06    ; usage (keyboard)
    	retlw   0xA1
    	retlw   0x01    ; collection (application)
    	retlw   0x05
    	retlw   0x07    ;   usage (Key codes)
    	retlw   0x19
    	retlw   0x04    ;   usage minimum (224)   e0   04
    	retlw   0x29
    	retlw   0xE7    ;   usage minimum (231)
    	retlw   0x15
    	retlw   0x00    ;     logical minimum (0)
    	retlw   0x25
    	retlw   0x01    ;     logical maximum (1)
    	retlw   0x75
    	retlw   0x01    ;     report size (1)
    	retlw   0x95
    	retlw   0x08    ;     report count (8)
    	retlw   0x81
    	retlw   0x02    ;     Input (data,variable,absolute)
    	retlw   0x95
    	retlw   0x01    ;     report count (1)
    	retlw   0x75
    	retlw   0x08    ;     report size (8)
    	retlw   0x81
    	retlw   0x01    ;     Input (constant)
    	retlw   0x95
    	retlw   0x05    ;     report count (5)
    	retlw   0x75
    	retlw   0x05
    	retlw   0x08    ;     usage page (page# for leds)
    	retlw   0x19
    	retlw   0x01    ;     Usage minimum (1)
    	retlw   0x29
    	retlw   0x05    ;     Usage maximum (5)
    	retlw   0x91
    	retlw   0x02    ;     output (data,variable,absolute)
    	retlw   0x95
    	retlw   0x75
    	retlw   0x03    ;     report size (3)
    	retlw   0x91
    	retlw   0x01    ;     output (constant)
    	retlw   0x95
    	retlw   0x06    ;     report count (6)
    	retlw   0x75
    	retlw   0x15
    	retlw   0x25
    	retlw   0x65    ;     logical maximum (101)
    	retlw   0x05
    	retlw   0x07    ;     usage page (keycodes)
    	retlw   0x19
    	retlw   0x00    ;     usage minimum (0)
    	retlw   0x29
    	retlw   0x65    ;     usage maximum (101)
    	retlw   0x81
    	retlw   0x00    ;     input (data, array)
    	retlw   0xC0    ;   end collection
    USB_SD_Ptr
    Strings
    	db	low String0, high String0
    	db	upper String0, 0
    	db	low String1, high String1
    	db	upper String1, 0
    	db	low String2, high String2
    	db	upper String2, 0
    String0
    	retlw   (String1-String0)/2	       ; Size of this descriptor in bytes
    	retlw   USB_DESCRIPTOR_STRING      ; STRING descriptor type
    	retlw   0x09                       ; Language ID as defined by MS - 0x0409 (low byte)
    	retlw   0x04                       ; (high byte)
    String1
    	retlw	(String2-String1)/2
    	retlw   'R'
    	retlw   0x00
    	retlw   'J'
    	retlw   0x00
    	retlw   'C'
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   'E'
    	retlw   0x00
    	retlw   'L'
    	retlw   0x00
    	retlw   'E'
    	retlw   0x00
    	retlw   'C'
    	retlw   0x00
    	retlw   'T'
    	retlw   0x00
    	retlw   'R'
    	retlw   0x00
    	retlw   'O'
    	retlw   0x00
    	retlw   'N'
    	retlw   0x00
    	retlw   'I'
    	retlw   0x00
    	retlw   'C'
    	retlw   0x00
    String2
    	retlw	(EndStringDescriptors-String2)/2
    	retlw   'H'
    	retlw   0x00
    	retlw   'I'
    	retlw   0x00
    	retlw   'D'
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   'K'
    	retlw   0x00
    	retlw   'E'
    	retlw   0x00
    	retlw   'Y'
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   'T'
    	retlw   0x00
    	retlw   'E'
    	retlw   0x00
    	retlw   'S'
    	retlw   0x00
    	retlw   'T'
    	retlw   0x00
    	retlw   'E'
    	retlw   0x00
    	retlw   'R'
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   ' '
    	retlw   0x00
    	retlw   '0'
    	retlw   0x00
    	retlw   '1'
    	retlw   0x00
    	Endasm
    kypd_desc_end			' End of skipped over USB assembler code
    Although these are original from Peter MacLeod, they have suffered many changes in an effort of getting things to start working.
  1. remote code learning
    Last Post: - 21st February 2021, 16:38
  2. 18F2431 Learning Curve
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 25th June 2012, 16:41
  3. Learning Stepper motor
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 20th April 2009, 07:23
  4. Learning Basic
    By bartman in forum General
    Last Post: - 19th November 2004, 01:45
