correct in both counts ,ruler is in cm and housing is plastic
Maybe this would work using one axis. I bought one but have not tried it yet.
http://www.ebay.com/itm/HMC5883L-Tri...item4d1e7ea3b8
Add:
I just found this pdf. There is a reference to an example in basic
http://www.parallax.com/sites/defaul...ation-v1.0.pdf
http://www.parallax.com/search?searc...ompass&=Search
I did testing of the Honeywell SS441 on the bench and max range is only about 1 inch. And that's with very strong neo magnets so I'll order some hmc1001's.
And I'm still looking for RFID units with decent range.
Sam
SkyeTek is the closest RFID I have found so far but I am still looking for a good 2' range unit a the lower price point.
Norm
If you want an RFID solution this thingy, http://www.farnell.com/datasheets/682634.pdf says it has less than 24 inch range and costs around $8 American, not including shipping. This is one of the readers from TI, http://www.farnell.com/datasheets/1719520.pdf, but I dont' think it has an antenna and that would be another expense. I wonder though if you couldn't have more than one antennae but use that same reader module. That way you could not only open the door but dispense a treat, daily food and/or water depending on where the dog, or the owner, brought a key fob.
The only reason I picked TI is that their stuff came up first during a search and I tried to get matching technologies. There were several different manufacturers but our company uses Newark for most of our common electronic parts supply so I'm basing cost off their prices. I'm not an engineer or a usually fully successful experimenter. I just had some time free for searching.
I'm assuming through all this you want to make sure your doggy door opens for your dog and not someone or something holding a magnet. Best of luck and please keep the forum updated.
