LAB1X sample code not working with 25LC640.
Results 1 to 11 of 11
    Jun 2009
    Sc*nthorpe, UK
    Default Re: LAB1X sample code not working with 25LC640.
    The datasheet http://ww1.microchip.com/downloads/e...Doc/21223H.pdf says
    2.6 Hold (HOLD)
    The HOLD pin is used to suspend transmission to the
    25XX640 while in the middle of a serial sequence without
    having to retransmit the entire sequence over
    again. It must be held high any time this function is not
    being used.
    So tie the HOLD pin high.
    Jun 2009
    Sc*nthorpe, UK
    Here is an app note http://ww1.microchip.com/downloads/e...tes/01018A.pdf
    which contains a wiring diagram.
    I hope this gives you some clues as to why the code is not working.
    Does not works anyway....
    Jun 2009
    Sc*nthorpe, UK
    In the original program there is this line
    TRISA.5 = 0 ' Set CS to output
    I do not see the equivalent line in your program.
    Which would be
    TRISB.3 = 0 ' Set CS to output
    Aren't ports automatically set to required state by apropriate statement, when needed?
    Anyways, found another code that worked:
    ' Program 25LC640.BAS
    ' * For use with EXPERIMENTING WITH THE PICBASIC PRO COMPILER *
    ' *  This source code may be freely used within your own      *
    ' *  programs. However, if it is used for profitable reasons, *
    ' *        please give credit where credit is due.	      *
    ' *  And make a reference to myself or Rosetta Technologies   *
    ' *			Les. Johnson			      *
    ' Write to the first 11 locations of a MICROCHIP 25LC640 SPI serial eeprom
    ' Then Read the 11 locations back and display them on a serial LCD
    ' The configuration is 8192 words x 8-bits
    ' To WRITE to the eeprom:-
    ' The 16-bit address is loaded into the variable "ADDR"
    ' The byte to write is loaded into the variable "E_BYTEOUT"
    ' And a call is made to the subroutine "EWRITE"
    ' To READ from the eeprom:-
    ' And a call is made to the subroutine "EREAD"
    ' The byte at the specified address is returned in the variable "E_BYTEIN"
    	Include "Modedefs.Bas"
    ' ** Setup the Crystal Frequency, in Mhz **
    	Define 	OSC		4		' Set Xtal Frequency
    ' ** Set Debug Defines **
    	Define	DEBUG_REG	PortA		' Debug PORT ?
    	Define	DEBUG_BIT	0		' *** Debug pin Bit ? ***
    	Define	DEBUG_BAUD	9600		' *** Debug Baud Rate ***
    	Define	DEBUG_MODE	1		' Set Serial Mode 1=Inverted
    	Define	DEBUG_PACING	300		' Delay 'in uS' between characters sent
    ' ** Define LCD Constants **
    	I		Con	254		' Control Byte
    	Clr		Con	1		' Clear the display
    	Line1		Con	128		' Point to beginning of line 1
    	Line2		Con	192		' Point to beginning of line 2
    	Line3		Con	148		' Point to beginning of line 3
    	Line4		Con	212		' Point to beginning of line 4
    ' ** Define the Pin assignments **
    	CS      	Var     PortB.0         ' Chip select pin
    	SCK     	Var     PortB.1         ' Clock pin
    	SI      	Var     PortB.2         ' Data in pin
    	SO      	Var     PortB.2         ' Data out pin
    ' ** Declare the Variables **
    	Addr    	var     Word            ' Memory address within the eeprom (0-511)
    	E_Byteout	Var	Byte		' Byte to be placed into the eeprom
    	E_Bytein	Var	Byte		' Byte read from the eeprom
    ' ** Define the eeprom's op-codes **
    	WRSR		Con	1		' Write to STATUS REGISTER op-code
    	EWR		Con	2		' WRITE op-code
    	ERD		Con	3		' READ op-code
    	WRDI		Con	4		' DISABLE WRITES op-code
    	RDSR		Con	5		' Read the STATUS REGISTER op-code
    	EWEN		Con	6		' ENABLE WRITES op-code
    ' ** THE MAIN PROGRAM STARTS HERE **
    ' Write the string, "HELLO WORLD" into the first 11 address's of the Eeprom
            For Addr=0 To 10                	' Create a loop of 11
    	Lookup Addr,["H","E","L","L","O"," ","W","O","R","L","D"],E_ByteOut' Build up the string
    	Gosub EWrite				' Write the byte to the Eeprom
            Next					' Close the Loop
    ' Read the first 11 address's within the Eeprom and display them on the LCD
    Again:  Debug I,Clr:Pause 30			' Clear the LCD
    	Pause 500				' Pause for drama
    	Gosub ERead				' Read the byte from the Eeprom
            Debug E_ByteIn  			' Display the characters read in from the eeprom
    	Pause 300				' Pause between characters being displayed
            Next					' Close the loop
            Goto Again				' Do it forever
    ' Read a single byte from the Eeprom
    ' The address is held in the variable "ADDR"
    ' The byte read is returned in the variable "E_BYTEIN"
    Eread: 	Low CS                          	' Enable the eeprom
            Shiftout SI,SCK,MSBFIRST,[ERD,Addr.highbyte,Addr.lowbyte]' Send READ COMMAND and address
            Shiftin SO,SCK,MSBPRE,[E_Bytein]   	' Read data
            High CS                          	' Disable the eeprom
    ' Write a single byte to the Eeprom
    ' The byte to be written is held in the variable "E_BYTEOUT"
    Ewrite: Low CS                         		' Enable the eeprom
            Shiftout SI,SCK,MSBFIRST,[EWEN]       	' Send WRITE ENABLE command
            High CS                          	' Disable the eeprom, to execute the command
            Low CS                          	' Re-enable the eeprom
            Shiftout SI,SCK,MSBFIRST,[EWR,Addr.highbyte,Addr.lowbyte,E_Byteout]' Send address and data
    	Pause 5                			' Allow the eeprom to allocate the byte
  1. BH1750FVI sample code available?
    Last Post: - 17th May 2022, 08:38
  2. Please help with sample code on 12f675
    By critix in forum mel PIC BASIC Pro
    Last Post: - 18th June 2013, 04:08
  3. please who can help me for sample code
    By jasem700 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 21:41
  4. USBJADEM sample code
    By SterlingY in forum mel PIC BASIC Pro
    Last Post: - 14th March 2007, 01:57
  5. Sample code for pwm
    By Md.Shah in forum mel PIC BASIC
    Last Post: - 10th October 2006, 17:59
