LAB1X sample code not working with 25LC640.
Results 1 to 11 of 11
    Default LAB1X sample code not working with 25LC640.
    Hello.
    I've decided to use 25LC640 EEPROM with 16F870. For that purpose, I've took the LAB1X code from here:
    http://melabs.com/samples/LABX1-16F887/spix.htm
    and modified it to my needs( just changed LCD and EEPROM ports and added details to info screen):
    include "modedefs.bas"
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    ADCON1=%00000110 'CONFIGURE PORT A AS DIGITAL
    CS  Var PORTB.3  ' Chip select pin
    SCK Var PORTC.6  ' Clock pin
    SI  Var PORTC.5  ' Data in pin
    SO  Var PORTB.2  ' Data out pin
    addr Var Word    ' Address
    B0   Var Byte    ' Data
       For addr = 0 To 15  ' Loop 16 times
         B0 = addr + 100   ' B0 is data for SEEPROM
         Lcdout $fe,1,#addr,": ",#B0 ' Display
         Lcdout $fe,$C0,"Writing...   " ' Display
         Gosub eewrite     ' Write to SEEPROM
         Pause 10          ' Delay 10ms after each write
       Next addr
    mainloop:
         Gosub eeread      ' Read from SEEPROM
         Lcdout $fe,$C0,"Reading...   " ' Display
         Pause 1000
       Next addr
       Goto mainloop
    ' Subroutine to read data from addr in serial EEPROM
    eeread:
       CS = 0              ' Enable serial EEPROM
       Shiftout SI, SCK, MSBFIRST, [$03, addr.byte1, addr.byte0] ' Send read command and address
       Shiftin SO, SCK, MSBPRE, [B0] ' Read data
       CS = 1              ' Disable
    ' Subroutine to write data at addr in serial EEPROM
    eewrite:
       Shiftout SI, SCK, MSBFIRST, [$06] ' Send write enable command
       CS = 1               ' Disable to execute command
       CS = 0               ' Enable
       Shiftout SI, SCK, MSBFIRST, [$02, addr.byte1, addr.byte0, B0] ' Send address and data
       CS = 1               ' Disable
    It appears to not write anything and reads the same sequence of 0s and 255 in each cycle, but the sequence is different on each power up.
    I was not able to find schematics how correctly wire another pins of EEPROM, such as HOLD. This can be wrong connection issue?
    Jun 2009
    Sc*nthorpe, UK
    Default Re: LAB1X sample code not working with 25LC640.
    The datasheet http://ww1.microchip.com/downloads/e...Doc/21223H.pdf says
    2.6 Hold (HOLD)
    The HOLD pin is used to suspend transmission to the
    25XX640 while in the middle of a serial sequence without
    having to retransmit the entire sequence over
    again. It must be held high any time this function is not
    being used.
    So tie the HOLD pin high.
    Jun 2009
    Sc*nthorpe, UK
    Here is an app note http://ww1.microchip.com/downloads/e...tes/01018A.pdf
    which contains a wiring diagram.
    I hope this gives you some clues as to why the code is not working.
    Does not works anyway....
    Jun 2009
    Sc*nthorpe, UK
    In the original program there is this line
    TRISA.5 = 0 ' Set CS to output
    I do not see the equivalent line in your program.
    Which would be
    TRISB.3 = 0 ' Set CS to output
    Aren't ports automatically set to required state by apropriate statement, when needed?
    Anyways, found another code that worked:
    ' Program 25LC640.BAS
    ' * For use with EXPERIMENTING WITH THE PICBASIC PRO COMPILER *
    ' *  This source code may be freely used within your own      *
    ' *  programs. However, if it is used for profitable reasons, *
    ' *        please give credit where credit is due.	      *
    ' *  And make a reference to myself or Rosetta Technologies   *
    ' *			Les. Johnson			      *
    ' Write to the first 11 locations of a MICROCHIP 25LC640 SPI serial eeprom
    ' Then Read the 11 locations back and display them on a serial LCD
    ' The configuration is 8192 words x 8-bits
    ' To WRITE to the eeprom:-
    ' The 16-bit address is loaded into the variable "ADDR"
    ' The byte to write is loaded into the variable "E_BYTEOUT"
    ' And a call is made to the subroutine "EWRITE"
    ' To READ from the eeprom:-
    ' And a call is made to the subroutine "EREAD"
    ' The byte at the specified address is returned in the variable "E_BYTEIN"
    	Include "Modedefs.Bas"
    ' ** Setup the Crystal Frequency, in Mhz **
    	Define 	OSC		4		' Set Xtal Frequency
    ' ** Set Debug Defines **
    	Define	DEBUG_REG	PortA		' Debug PORT ?
    	Define	DEBUG_BIT	0		' *** Debug pin Bit ? ***
    	Define	DEBUG_BAUD	9600		' *** Debug Baud Rate ***
    	Define	DEBUG_MODE	1		' Set Serial Mode 1=Inverted
    	Define	DEBUG_PACING	300		' Delay 'in uS' between characters sent
    ' ** Define LCD Constants **
    	I		Con	254		' Control Byte
    	Clr		Con	1		' Clear the display
    	Line1		Con	128		' Point to beginning of line 1
    	Line2		Con	192		' Point to beginning of line 2
    	Line3		Con	148		' Point to beginning of line 3
    	Line4		Con	212		' Point to beginning of line 4
    ' ** Define the Pin assignments **
    	CS      	Var     PortB.0         ' Chip select pin
    	SCK     	Var     PortB.1         ' Clock pin
    	SI      	Var     PortB.2         ' Data in pin
    	SO      	Var     PortB.2         ' Data out pin
    ' ** Declare the Variables **
    	Addr    	var     Word            ' Memory address within the eeprom (0-511)
    	E_Byteout	Var	Byte		' Byte to be placed into the eeprom
    	E_Bytein	Var	Byte		' Byte read from the eeprom
    ' ** Define the eeprom's op-codes **
    	WRSR		Con	1		' Write to STATUS REGISTER op-code
    	EWR		Con	2		' WRITE op-code
    	ERD		Con	3		' READ op-code
    	WRDI		Con	4		' DISABLE WRITES op-code
    	RDSR		Con	5		' Read the STATUS REGISTER op-code
    	EWEN		Con	6		' ENABLE WRITES op-code
    ' ** THE MAIN PROGRAM STARTS HERE **
    ' Write the string, "HELLO WORLD" into the first 11 address's of the Eeprom
            For Addr=0 To 10                	' Create a loop of 11
    	Lookup Addr,["H","E","L","L","O"," ","W","O","R","L","D"],E_ByteOut' Build up the string
    	Gosub EWrite				' Write the byte to the Eeprom
            Next					' Close the Loop
    ' Read the first 11 address's within the Eeprom and display them on the LCD
    Again:  Debug I,Clr:Pause 30			' Clear the LCD
    	Pause 500				' Pause for drama
    	Gosub ERead				' Read the byte from the Eeprom
            Debug E_ByteIn  			' Display the characters read in from the eeprom
    	Pause 300				' Pause between characters being displayed
            Next					' Close the loop
            Goto Again				' Do it forever
    ' Read a single byte from the Eeprom
    ' The address is held in the variable "ADDR"
    ' The byte read is returned in the variable "E_BYTEIN"
    Eread: 	Low CS                          	' Enable the eeprom
            Shiftout SI,SCK,MSBFIRST,[ERD,Addr.highbyte,Addr.lowbyte]' Send READ COMMAND and address
            Shiftin SO,SCK,MSBPRE,[E_Bytein]   	' Read data
            High CS                          	' Disable the eeprom
    ' Write a single byte to the Eeprom
    ' The byte to be written is held in the variable "E_BYTEOUT"
    Ewrite: Low CS                         		' Enable the eeprom
            Shiftout SI,SCK,MSBFIRST,[EWEN]       	' Send WRITE ENABLE command
            High CS                          	' Disable the eeprom, to execute the command
            Low CS                          	' Re-enable the eeprom
            Shiftout SI,SCK,MSBFIRST,[EWR,Addr.highbyte,Addr.lowbyte,E_Byteout]' Send address and data
    	Pause 5                			' Allow the eeprom to allocate the byte
    maybe if you
    high cs or low cs
    but
    cs=0 or c=1
    I don't think so
    Jun 2009
    Sc*nthorpe, UK
    It was not a connection issue then?
    What are the differences in the two programs that made the code in #1 not work?
    Jun 2009
    Sc*nthorpe, UK
    maybe if you
    high cs or low cs
    but
    cs=0 or c=1
    I don't think so
    So the first program will work if this line is included
    The difference is that SI and SO pins are tied together in 2nd code, via 1k resistor.
    Jun 2009
    Sc*nthorpe, UK
    From the first code
    eewrite:
    CS = 0 ' Enable
    CS = 1 ' Disable
    You are shifting out on the data in pin? Which is the same in the original SPIX.htm so I guess I am confused.
  1. BH1750FVI sample code available?
    Last Post: - 17th May 2022, 08:38
  2. Please help with sample code on 12f675
    By critix in forum mel PIC BASIC Pro
    Last Post: - 18th June 2013, 04:08
  3. please who can help me for sample code
    By jasem700 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 21:41
  4. USBJADEM sample code
    By SterlingY in forum mel PIC BASIC Pro
    Last Post: - 14th March 2007, 01:57
  5. Sample code for pwm
    By Md.Shah in forum mel PIC BASIC
    Last Post: - 10th October 2006, 17:59
