Rectified wave problem
Results 1 to 5 of 5
    Dec 2012
    Türkiye
    Default Rectified wave problem
    Hi everyone;
    I'm upto a triac control circuit . So , in order to control the triac triggering angle we need to detect the zero crossing points .. I've made the attached circuit schematic on a breadboard but I'm having too weird problem about the full wave rectified sine wave .. The rectified wave can not reach to zero cross twice but only once during a period and plots an unintended line as seen on the attached picture .. I've changed the circuit components for a thousands of times including the resistors , capacitors , bridge rectifiers , transistors even the breadboard ... The rectified wave even acts same on a single load resistor ...
    What could the problem be ?
    PLEASE HELP ... Name:  Zero cross detector.jpg
Size:  26.7 KBName:  WP_000045.jpg
Size:  151.6 KBName:  resim3.jpg
Size:  140.1 KBName:  resim2.jpg
Size:  141.1 KBName:  resim1.jpg
    Default Re: Rectified wave problem
    looks like your ac signal earth reference is biased one forward diode voltage above earth.
    you need something like this
    I use 'ac opto' to get 0xing. vary R3 to change width of the zero areaName:  zero xing.JPG
    oh, add series resister to opto input !!
    Dec 2012
    Türkiye
    I use 'ac opto' to get 0xing. vary R3 to change width of the zero areaAttachment 7388
    Thanks for your replies guys .
    To amgen ; Why would we still need the diodes and the cap since the AC opto and a series resistor are sufficient to detect the zero crosses ?
    I mean the following link would have sufficied I suppose ?
    http://i.stack.imgur.com/sw3mO.png
    thought that was part of your power supply stuff !! otherwise then not needed.
    don
  1. Replies: 6
    Last Post: - 31st March 2014, 13:25
  2. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 03:31
  3. square to sine wave help
    By TONIGALEA in forum General
    Last Post: - 2nd July 2006, 09:32
  4. 40 kHz wave
    By RUBiksCUbe in forum mel PIC BASIC Pro
    Last Post: - 14th December 2005, 20:01
  5. Wave Form Identifier
    By INaPickle in forum Schematics
    Last Post: - 6th November 2005, 08:49
