HOW DOES PBP handle bits varables to bytes
Results 1 to 9 of 9
    Default Re: HOW DOES PBP handle bits varables to bytes
    I've looked at this and although I'm not that good at assembly here how I believe it works.
    When you create a BIT variable the compiler allocates a BYTE of RAM and calls it PB1, your bit variable is then defined as the first bit in that byte. When you create a second BIT variable it gets defined as the second bit in the previously allocated BYTE (ie still only a single byte). When you create the 9th BIT variable a new BYTE is allocated (PB2) and so on. So, one BIT variable takes 1 BYTE but 8 bit variables still only takes ONE byte.
    Basically, this is what it looks like in the assembly listing:
    00081 PB01                            EQU     RAM_START + 019h
    00083 PB02                            EQU     RAM_START + 01Ah
    00092 #define _myBit1                  PB01, 000h
    00093 #define _myBit2                  PB01, 001h
    00094 #define _myBit3                  PB01, 002h
    00095 #define _myBit4                  PB01, 003h
    00096 #define _myBit5                  PB01, 004h
    00097 #define _myBit6                  PB01, 005h
    00098 #define _myBit7                  PB01, 006h
    00099 #define _myBit8                  PB01, 007h
    00100 #define _myBit9                  PB02, 000h
    As you can see, for 9 BIT variables only TWO bytes of RAM is allocated - thankfully and as expected.
    that's good to know , after misreading the manual at some stage I have been micro-managing bit vars needlessly for years .
    Nov 2007
    West Covina, CA
    Good question and answers!
    Like Richard, I have also been doing the same when it was already taken care of.
    Louie
    Last Post: - 14th June 2016, 07:55
  2. Configuation bits setting in PBP
    By Max_Gauss in forum mel PIC BASIC Pro
    Last Post: - 8th September 2010, 18:25
  3. Pickit 2 saving varables?
    By jessey in forum Off Topic
    Last Post: - 7th June 2010, 09:14
  4. 16/32 bits PIC support in PBP?
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 9th May 2010, 15:40
  5. Bits & Bytes
    By electronicsuk in forum mel PIC BASIC Pro
    Last Post: - 12th April 2006, 11:52
