need eeprom to save values
Results 1 to 14 of 14
    May 2008
    Italy
    Default Re: need eeprom to save values
    If you have a spare ADC pin available, than you can place a diode (1N4148 for example) and an electrolitic capacitor on the Vdd line to your pic. With the ADC you will monitor the power supply and when you detect a low ( you will establish the safe value) you will jump to the saving routine and write to eeprom all the necessary value the pic will need at start.
    An example of what I mean can be seen in the attached hand drawing.
    Cheers
    Al.
  1. Save a port number into the EEPROM?
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 20th August 2009, 10:06
  2. Save number cell in to EEprom
    By piombazzo in forum GSM
    Last Post: - 18th August 2008, 21:49
  3. Using serial eeprom to save data ?
    By iugmoh in forum General
    Last Post: - 8th February 2008, 09:36
  4. Replies: 5
    Last Post: - 29th January 2008, 10:19
  5. Replacing an ARRAY with EEPROM write to save space?
    Last Post: - 12th March 2005, 19:31
