need eeprom to save values
Results 1 to 14 of 14
    Default Re: need eeprom to save values
    Use a FET to control the power supply, the FET will be controlled by the PIC.
    When you give the PIC the command to kill the FET jump to a routine to write whatever is needed to the EEPROM, then kill the FET.
    This thread has a couple schematics and discussion that should help.
    http://www.picbasic.co.uk/forum/showthread.php?t=19293
    May 2008
    Italy
    If you have a spare ADC pin available, than you can place a diode (1N4148 for example) and an electrolitic capacitor on the Vdd line to your pic. With the ADC you will monitor the power supply and when you detect a low ( you will establish the safe value) you will jump to the saving routine and write to eeprom all the necessary value the pic will need at start.
    An example of what I mean can be seen in the attached hand drawing.
    Cheers
    Al.
    Jun 2011
    Indian Harbour Nova Scotia
    thanks a lot for this. Good link.
  1. Save a port number into the EEPROM?
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 20th August 2009, 09:06
  2. Save number cell in to EEprom
    By piombazzo in forum GSM
    Last Post: - 18th August 2008, 20:49
  3. Using serial eeprom to save data ?
    By iugmoh in forum General
    Last Post: - 8th February 2008, 08:36
  4. Replies: 5
    Last Post: - 29th January 2008, 09:19
  5. Replacing an ARRAY with EEPROM write to save space?
    Last Post: - 12th March 2005, 18:31
