Sala de peru
Results 1 to 9 of 9
Thread: Sala de peru
    Default Re: Sala de peru
    Cardservicios, Here is an A/D routine I wrote a few years back for accessing 2 MCP3551 A/D's for my daughter's hydroponic and heater controller. I did not use I2C hardware directly but maybe you can use it as a basis for an I2C routine.
    READMCP3551: 'CAPTURE MCP3551 22 BIT SIGMA/DELTA READING (SPI)
    SCL = 1 'PRESET CLOCK STATE TO HIGH
    SELECT CASE ADCHANNEL
    CASE 0
    CS0 = 0 'ENABLE MCP3551 #1
    CASE 1
    CS1 = 0 'ENABLE MCP3551 #2
    CASE ELSE
    VOLTS(ADCHANNEL) = 0
    END SELECT
    PAUSEUS 2
    IF SDA = 0 THEN 'CHECK FOR CONVERSION COMPLETE
    SHIFTIN SDA,SCL,6,[MSBYTE\8,MIDBYTE\8,LSBYTE\8]
    CS0 = 1 'DISABLE MCP3551 #1
    CS1 = 1 'DISABLE MCP3551 #2
    JUNK = MSBYTE >> 5
    SELECT CASE JUNK
    CASE 0 'NORMAL POSITIVE READING
    POLARITY = 0
    OVERANGE(ADCHANNEL) = 0
    CASE 1 'NORMAL NEGATIVE READING
    POLARITY = 1
    CASE 3 'FULL SCALE POSITIVE READING
    POLARITY = 0
    OVERANGE(ADCHANNEL) = 1
    CASE 4 'FULL SCALE NEGATIVE READING
    POLARITY = 1
    END SELECT
    IF OVERANGE(ADCHANNEL) = 0 THEN 'IF READING IS WITHIN LIMITS
    IF POLARITY = 0 THEN 'POSITIVE POLARITY
    ADSCRATCH1.BYTE3 = 0
    ADSCRATCH1.BYTE2 = (MSBYTE & %00011111)
    ADSCRATCH1.BYTE1 = MIDBYTE
    ADSCRATCH1.BYTE0 = LSBYTE
    ELSE 'POLARITY = 1 'NEGATIVE POLARITY
    ADSCRATCH1.BYTE3 = 255
    ADSCRATCH1.BYTE2 = MSBYTE | %11100000
    ADSCRATCH1.BYTE3 = 127
    ADSCRATCH1.BYTE2 = 255
    ADSCRATCH1.BYTE1 = 255
    ADSCRATCH1.BYTE0 = 255
    VOLTS(ADCHANNEL) = ADSCRATCH1
    EN82fn
    thanks for your help
    thanks for your help, I am new to programming have a simple example
