Sala de peru
Results 1 to 9 of 9
Thread: Sala de peru
    Smile Sala de peru
    Quiero hacer una comunicacion spi con un conversor analogo digital de 24 bit ALGUIEN ME PUEDE GUIAR CON LA PROGRAMACION MCP3421 MICROCHIP
    Edit, English: I want to make a spi communication with a digital analog converter 24 bit CAN ANYONE GUIDE ME WITH MICROCHIP MCP3421 PROGRAMMING
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Sala de peru
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by cardservicios View Post
    Yes help will be available here. What do you need to know?
    Jun 2009
    Sc*nthorpe, UK
    Do you want DAC or ADC? The MCP3421 is 18 bit ADC. Not 24 bit digital analogue converter.
    I want an example of communication spi mcp3551
    I want an example of communication spi mcp3551 A/D.
    with pic 16f877a in pic basic pro
    Jun 2009
    Sc*nthorpe, UK
    Have you made a start on this?
    Cardservicios, Here is an A/D routine I wrote a few years back for accessing 2 MCP3551 A/D's for my daughter's hydroponic and heater controller. I did not use I2C hardware directly but maybe you can use it as a basis for an I2C routine.
    READMCP3551: 'CAPTURE MCP3551 22 BIT SIGMA/DELTA READING (SPI)
    SCL = 1 'PRESET CLOCK STATE TO HIGH
    SELECT CASE ADCHANNEL
    CASE 0
    CS0 = 0 'ENABLE MCP3551 #1
    CASE 1
    CS1 = 0 'ENABLE MCP3551 #2
    CASE ELSE
    VOLTS(ADCHANNEL) = 0
    END SELECT
    PAUSEUS 2
    IF SDA = 0 THEN 'CHECK FOR CONVERSION COMPLETE
    SHIFTIN SDA,SCL,6,[MSBYTE\8,MIDBYTE\8,LSBYTE\8]
    CS0 = 1 'DISABLE MCP3551 #1
    CS1 = 1 'DISABLE MCP3551 #2
    JUNK = MSBYTE >> 5
    SELECT CASE JUNK
    CASE 0 'NORMAL POSITIVE READING
    POLARITY = 0
    OVERANGE(ADCHANNEL) = 0
    CASE 1 'NORMAL NEGATIVE READING
    POLARITY = 1
    CASE 3 'FULL SCALE POSITIVE READING
    POLARITY = 0
    OVERANGE(ADCHANNEL) = 1
    CASE 4 'FULL SCALE NEGATIVE READING
    POLARITY = 1
    END SELECT
    IF OVERANGE(ADCHANNEL) = 0 THEN 'IF READING IS WITHIN LIMITS
    IF POLARITY = 0 THEN 'POSITIVE POLARITY
    ADSCRATCH1.BYTE3 = 0
    ADSCRATCH1.BYTE2 = (MSBYTE & %00011111)
    ADSCRATCH1.BYTE1 = MIDBYTE
    ADSCRATCH1.BYTE0 = LSBYTE
    ELSE 'POLARITY = 1 'NEGATIVE POLARITY
    ADSCRATCH1.BYTE3 = 255
    ADSCRATCH1.BYTE2 = MSBYTE | %11100000
    ADSCRATCH1.BYTE3 = 127
    ADSCRATCH1.BYTE2 = 255
    ADSCRATCH1.BYTE1 = 255
    ADSCRATCH1.BYTE0 = 255
    VOLTS(ADCHANNEL) = ADSCRATCH1
    EN82fn
    thanks for your help
    thanks for your help, I am new to programming have a simple example
