microcontroller vs plc vs 'microprocessor w/ peripherals'
Results 1 to 5 of 5
    Mar 2007
    Philippines
    Default microcontroller vs plc vs 'microprocessor w/ peripherals'
    i worked as a technician for a japanese company that shall remain undisclosed but anyway in the machines in their assembly line i saw on a machine that it had more than one plc(programmable logic controller) in it, as well as a computer but with no monitor (machine just interfaced to the computer via a port) and i dont know if it had any microcontroller chips in it.. but anyway i have a few questions
    why would a control system need all of these? why cant one control the whole thing? why more than one plc? what can a plc do that a micro or a microcontroller or microprocessor can't? and vice-versa? all i know is that a plc is usually more expensive than a microcontroller so what exactly are you getting for that extra you're spending?
    Default Re: microcontroller vs plc vs 'microprocessor w/ peripherals'
    Without more details on the application, multiple microcontrollers can be used in a modular approach. One microcontroller per task; it makes for simplified programming = lower costs.
    There are many other advantages: you can replace one defective module, no need for expensive high-end multi-feature microcontroller, easier to add future modules, etc.
    I always design in a modular fashion. It's so much easier to program, debug and repair.
    (I have no experience with PLC)
    Mar 2007
    Philippines
    ah yes modular design would be a perfect reason to have multiple 'brains' handling control rather than one that is centralized... makes sense for industries
    Many machine builders use PLC's for there logic control because they are mass produced and usually available on quanity's. Also PLC's are already designed which allows the machine builder concentrate on the machine mechanics instead of designing new circuit boards and logic and interfacing. Most PLC's use LADDER LOGIC for programming which allows PLC software engineers to understand each others software.
    EN82fn
    Quote Originally Posted by Humbleworker View Post
    makes sense for Hobbyist as well, if you can use 2 $0.49 PICs instead of an $8.00 PIC too. One other advantage is you don't have to concern yourself with how timing of one function affects the other function.
  1. Other Microprocessor support?
    By rtsandiego in forum PBP Wish List
    Last Post: - 31st December 2009, 00:17
  2. Tutor Microprocessor
    By OiFlymo in forum Off Topic
    Last Post: - 19th April 2009, 15:17
  3. Replies: 0
    Last Post: - 7th August 2008, 09:02
  4. changing code from 16F to 18F microprocessor
    By SCC_699 in forum mel PIC BASIC Pro
    Last Post: - 14th May 2008, 13:27
  5. Default microprocessor
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 9th November 2007, 16:04
