setting values and percentages
Results 1 to 38 of 38
Threaded View
  1. #27
    Jun 2009
    Sc*nthorpe, UK
    Default Re: setting values and percentages
    Quote Originally Posted by EarlyBird2 View Post
    Now I understand what you are saying. It does seem odd to me that there is a 32 bit register for maths calculation which can not be used if there is a word or byte variable in the calculation because the word/byte variable could overflow. A bit more thinking is required on my part, I think.
    Does this mean that using ** and */ uses 32 bit and * only 16 bit?
    After more thought and a bit of direction to look at DIV32 by Dave.
    Multiplication stores a 32 bit result internally but the normal divide only works on the lower 16 bits which causes the 'overflow' problem highlighted by Richard. DIV32 was created specifically to overcome the 16 bit division limitation and as Dave says is a solution here.
    Scampy asked about */ and how that works. It works by removing the division in the calculation so there is no 16 bit divide, there is an 8 bit shift or a divide by 256 of the 32 bits whichever way one wishes to visualise the process. Knowing that */ will apply a division by 256 one has to take account of this in the program.
    In this case
    B_max = (4095/100)*maxbright
    take 4095/100 and multiply by 256 giving 10483.2 which is rounded up to 10484. Resulting in this
    B_max = maxbright*/10484 which results in an integer value of 2047 when maxbright is 50.
  1. POT part values
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 10:41
  2. Port Values
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2007, 20:44
  3. t in POT, c's values
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 24th August 2006, 23:30
  4. Numeric Values
    By Armando Herjim in forum General
    Last Post: - 28th June 2006, 01:54
  5. Wrong values with COSINE!
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 8th May 2006, 16:59
