Don't know what happened to my post last night, but I found out why it was doing that - It was one of those oversights caused through hours of programming without a break. The menu option saved all the changes when exiting from the menu to the main program, so unless this action was performed all the changes were lost if you remained in the menu section as the diagnostics option reads the values stored in memory and thus read the defaults and over wrote them. This was changed so each section of the menu now writes the new values to memory when exiting the option and reverting back to the menu screen, so switching between menu options and then the diagnostics means that the changes made in any of the other menu sections are read back in.
One thing I would like to know is what the */ function means
