setting values and percentages
Results 1 to 38 of 38
    Default Re: setting values and percentages
    How about
    PWMValue = Percentage */ 10483
    Oct 2009
    Bit of a fudge, but it works well enough
    ' Set Brightness levels for each channel
    brightness:
    B_max = (4095/100)*maxbright
    Lcdout $FE,2
    LCDOUT $FE,$80,"Set Max Brightness"
    IF H_butt = 0 THEN GOSUB up
    IF M_butt = 0 THEN GOSUB down
    If maxbright  = 100 then
    LCDOUT $FE,$C0,"Channel 1 "
    LCDOut $FE,$D4,#maxbright,"%"
    If maxbright  =0 or maxbright <10 then
    LCDOUT$FE,$C0,"Channel 1 "
    LCDOut $FE,$D4,dec1 maxbright,"% "
    if maxbright >=10 and maxbright <100 then
    LCDOut $FE,$D4,dec2 maxbright,"%   "
    If S_butt = 0 then
        goto brightness2
    goto brightness
    brightness2:
    W_max = (4095/100)*maxbright
    Lcdout $FE,2
    LCDOUT $FE,$C0,"Channel 2 "
    LCDOUT$FE,$C0,"Channel 2 "
    pause 200
    If S_butt = 0 then
        LCDOUT $FE,1
        goto mainmenu
    goto brightness2
    up:
        maxbright = maxbright + 1
        IF maxbright >= 100 THEN maxbright = 100
        pause 250
    down:
        maxbright = maxbright - 1
        IF maxbright <= 0 THEN maxbright = 0
        pause 250
    Again, the lack of floating point maths in PBP means the calculations are not exact, but this way every 1% increment equals a block of 41 steps on the PCA chip, so 50% brightness = 2050 but that's close enough to the 2047 is should be and to be honest I doubt if the human eye could distinguish the difference
    If it works it works.
    If you want it a little better PWMValue = Percentage */ 10483 will give you 2047 at 50%.
    Oct 2009
    So using my variables B_max = (4095/100)*maxbright would that be
    B_max = maxbright */10483
    Nope - that don't work
    If B_Max is the value you send to the PWM controller (0-4095) and maxbright is the percentage value (0-100) as entered by the user then yes.
    Actually, at 100% it'll give you 4094 so make that B_max = maxbright */10484 instead.
    Oct 2009
    Yes - B_max and W_max are the values that are sent to the PCA chip (0 - 4095). And maxbright has a value between 0 and 100 as you assumed. But using that line of code the values for B_max and W_max do not change from the pre-programmed default of 4095 after the menu option is used to change the max brightness level
    Strange..... I tested the following code
    HSEROUT["Program start",13]
    For i = 0 to 5
        Lookup2 i,[1, 10, 25, 50, 75, 100], maxbright
        B_max = maxbright */ 10484
        HSEROUT ["Maxbright: ", DEC3 maxbright, "     B_Max: ", DEC4 B_max, 13]
    NEXT
    And got the following results:
    Program start
    Maxbright: 001     B_Max: 0040
    Maxbright: 010     B_Max: 0409
    Maxbright: 025     B_Max: 1023
    Maxbright: 050     B_Max: 2047
    Maxbright: 075     B_Max: 3071
    Maxbright: 100     B_Max: 4095
    Seems to work fine here....
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by Scampy View Post
    Is the default of 4095 inside the main loop and resetting B_max and W_max after the menu option returns to the main loop.
  1. POT part values
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 11:41
  2. Port Values
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2007, 21:44
  3. t in POT, c's values
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 25th August 2006, 00:30
  4. Numeric Values
    By Armando Herjim in forum General
    Last Post: - 28th June 2006, 02:54
  5. Wrong values with COSINE!
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 8th May 2006, 17:59
