If B_Max is the value you send to the PWM controller (0-4095) and maxbright is the percentage value (0-100) as entered by the user then yes.
Actually, at 100% it'll give you 4094 so make that B_max = maxbright */10484 instead.
Yes - B_max and W_max are the values that are sent to the PCA chip (0 - 4095). And maxbright has a value between 0 and 100 as you assumed. But using that line of code the values for B_max and W_max do not change from the pre-programmed default of 4095 after the menu option is used to change the max brightness level
