RANDOM and 12F683 - generates same values each time
Results 1 to 13 of 13
    Default Re: RANDOM and 12F683 - generates same values each time
    Tested the above code. On power up, it gives 3 and 6 on 16f870 and 2 and 4 on 12f683, same results on each power up.
    however, if I place it in the loop, results on 16f870 are changing, while on 12f683 they remain 2 and 4.
    OK, the fact that you don't get the exact same sequence from the two devices could possibly (I don't know) come from the different instruction width (12 vs 14 bits) between the two. But why the 12F683 doesn't continue the sequence when the routine is looped is beyond me.
  1. Adding values one at a time and sending them serially
    Last Post: - 21st August 2013, 15:56
  2. Why does this PBP statement post the wrong time values?
    Last Post: - 22nd November 2011, 04:10
  3. DS1904 RTC - How to Convert Binary Time into Real Time/Date?
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2010, 11:45
  4. LCDOUT generates errors.
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 17th September 2009, 18:58
  5. Linx RF -> HSERIN time delay / time critical app...
    By batee in forum mel PIC BASIC Pro
    Last Post: - 15th October 2004, 16:04
