I see a few threads about the nRF24L01, and I was able to get simple messaging going with a pair of nRF24L01's, but has anybody played with the nRF905? It's a little slower, but has significantly better range and is more forgiving when it comes to trees or other organics between Rx and Tx. The pinout is different (more pins) which seems to suggest the 24L01 code isn't going to work, although there are similarities.
I *can* start from the datasheet - I've put a lot of hours into going through it already - but it would certainly save a lot of time if somebody has put some routines together that I can simply build on. There's "C" around for Arduino, but it's almost like the BASIC folks have never looked at this device. Search does not turn up a single reference.
