Minimize battery consumption on a 18F2550
Results 1 to 26 of 26
    Default Re: Minimize battery consumption on a 18F2550
    First thing is to go through the datasheet and disable as many features as you can. That should save energy.
    I have no experience with sleep feature.
    May 2008
    Italy
    I can suggest to switch off everything when not used, so you will have no power drain. When you press any button to activate the proper command, you will switch on the system via a small fet activated with an array of diodes so that any button will switch on the fet. Your pic as activated will retain the fet on for all the time necessary to process the comand then it will switch off the fet again.
    Cheers
    Al.
    Apr 2011
    Welches, Oregon
    Here is a thread on the subject: http://www.picbasic.co.uk/forum/showthread.php?t=6134
    I liked the idea (coolness factor) of a "touch sensitive" case...
    BTW. If you're not using the USB part of the Mikro board, you can save most of the $26 ($17.10 plus $9) and make a smaller board if you build the whole thing on stripe board. Also, you might find it easier to mount the RF module securely. Just a thought, although perhaps the convenience is worth it to you.
    Jan 2008
    Thank you for your replay.
    How do I do that and what parts do I need?
    Do you have an example or schematic?
    Quote Originally Posted by aratti View Post
    Cheers
    Al.
    May 2008
    Italy
    Something like this should be a good starting point.
    Cheers
    Al.
    Jan 2008
    Thanx
    Can it also be done with a N-ch FET like the 2N7000 in some way?
    Jan 2008
    Will this schematic work?
    When u press a button the FET will switch on the 7805 and the PIC, and then I hold RA4 low as long I want the PIC to run.
    The +BATT terminal is from a 9V battery and the datasheet says that RA4 can handle up to 14 volts if I have understand it right, so 9V on RA4 will be OK?
    Sep 2009
    It wont work. Because if PIC doesn't have power supply, current still can be drown from pin, and that will be probably enough to turn on fet. Even if RA4 is open drain, you can put more than VDD+0.6 on that pin. If you do this, you will damage input buffer.
    So you need to to put transistor to bring down gate. Depending on P FET you use and battery voltage, maybe you need to put another resistor to create voltage divider for gate.
    EDIT:
  1. Replies: 13
    Last Post: - 22nd January 2012, 05:48
  2. Fuel consumption display
    By veijavi in forum mel PIC BASIC Pro
    Last Post: - 27th December 2011, 07:05
  3. Gasoline consumption Math
    By srspinho in forum General
    Last Post: - 12th November 2007, 11:21
  4. 12F683 battery powered remote - energy consumption question
    By silentwol in forum mel PIC BASIC Pro
    Last Post: - 13th April 2007, 14:23
  5. low power consumption
    By taos in forum General
    Last Post: - 26th February 2006, 09:33
