I need to measure alot of different frequencies at the same time (up to 48) How?
Results 1 to 13 of 13
    Default Re: I need to measure alot of different frequencies at the same time (up to 48) How?
    You can do it that way if you don't want accurate information. When a bag of corn seed costs over $300 (that is a 50 lb bag) you can't take anything for granted and every row is monitored. Plus with my electric planter drives I vary population on a row by row basis so it gets pretty important then too.
    www.electricplanter.com
    The sensor detects each seed passing through the seed tube after is falls from the seed plate on its way to the ground.
    Quote Originally Posted by EarlyBird2 View Post
    I thought that on a seed drill all of the disks rotated at the same speed and the spread rate was a simple calculation involving the number of slots and rpm. This would mean that only one disk needs to be monitored to calculate the spread rate. The complication is detecting missed seeds for which each disk has to have a detector. So the question is what form does the existing detector take does it count seeds or missed seeds? I would have thought the latter and if that is the case then the application becomes easier.
    Jun 2009
    Sc*nthorpe, UK
    That is impressive!
    It not only counts the seeds on each row it also controls the rate of each row automatically.
    Thank you.
    It started out as something Dad and I wanted to do on his corn planter six years ago. Now I have sold over 4000 units in the US, UK, AUS, SA, and Ukraine over the last five years. This next year I bet I sell 4000 more.
    Its taken on a life of its own.
    Jun 2009
    Sc*nthorpe, UK
    You have a working system that counts each seed, works out the spread rate and adjusts the rate to meet a set value.
    What sensor are you using to detect the seeds being dropped? I have used pulse counter chips as counters combine this with a clock timing of 100 ms will give spread rate seeds/second presumably tractor speed is also needed to give seed/metre.
    From calculating spread rate the drill has to adjust the rate too the set rate. Will the PIC do this or is there some other control on board the tractor to do this?
    I am thinking along the lines of 48 slave counters with serial connection to master controller. I can visualise what the slaves will do but can only guess at how the master will adjust the spread rate.
    I don't know true seed count as of now. My electric drives work two ways; with a hydraulic rate controller or a rate controller I make based on an Adroid tablet.
    For the first example, I have an Interface board that connects to the PWM output of a standard rate controller. It measures the PWM signal and makes the rate controller think a hydraulic drive is connected. By measuring the PWM and providing a feedback signal to the rate controller I am able to figure out how the rate controller is trying to spin a hydraulic drive. Normally a hydraulic drive spins the seed plates. So once I calculate the desired rpm needed by the rate controller based on row spacing, seed plate count, ground speed and needed population, I send the rpm number to the Control board. The Control board handles four rows individually. The slick thing is I send this data wirelessly from the Interface board to the Control board so the only connection I need between tractor and planter is power and ground.
    The Interface board also connects to the 'section control' outputs. On a hydraulically driven planter farmers can use electric clutches on each row to engage/disengage the drives to minimize seed waste. I connect to these outputs to know which rows need to be on/off.
    Each electric drive has an encoder that I use to measure rpm and adjust accordingly with a PID routine.
    At current time, with a rate controller from another manufacturer or using my Android based rate controller, there is a 'Seed Monitor' It is connected to a seed sensor on each row of the planter. It is basically an optic sensor on the seed tube between the seed plate and the ground. It pulls low when the seed is in front of the seed sensor. Its not even close to being a 50% duty cycle.
    If a farmer uses my rate controller, he is stuck with another display in his tractor that is the seed monitor. I want to integrate seed monitoring into my rate controller. I do display on my rate controller UI a population number but that is based purely from the encoder, not the seed being dropped into the ground.
    The big thing in planting corn is being able to detect skips...when a seed is supposed to be dropped yet not. This is usually due to the vacuum pulling a seed against the seed plate not being correct. So I really need to be able to measure population based on seed drop from the seed sensor, display it on my Android UI and also throw up a flag on the UI when a skip is detected also.
    I have started to work on the PIC32 chips but I am still running into the amount of available CCP/Input Capture pins not going up to 48 on a single processor. A 48 row planter is pretty rare but I need to be able to handle it. The majority of my customers are in the 12-16 row range.
    Jun 2009
    Sc*nthorpe, UK
    Pulse counter connected to PIC for serial communication looks the way forward. Have one pulse counter and PIC for each row. Just need to test a pulse counter that works with the seed drop pulse. I have used this for example CD4520BEE4 it counts in the background and outputs the count to four pins on the PIC. The count is simply read by sampling the port. They are cascade able so can be connected to give 8, 12, 16 ... bit counts. The PIC will read the port and send to the UI, which you have already sorted out.
    I presume that as there is a PIC on each row it could also be used to control the motor.
    Sep 2010
    Las Vegas, NV
    You know some of things you think are pretty simple like a farmer planting seeds are indeed quite technical and wireless to boot. Awesome integration of technology with one of the most basic requirements of society. Very interesting project that will make me look at using PICs in different ways. Thanks. I hope you find an answer to your desire.
  1. How to Measure 2 or more digital inputs a the same time
    Last Post: - 29th April 2013, 02:23
  2. how to measure RPM and SPEED at the same time
    By teeeeee in forum mel PIC BASIC Pro
    Last Post: - 30th July 2012, 08:34
  3. Measure time in mS between two pulses
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 7th March 2011, 07:20
  4. CCP1 and CCP2 to measure 2 frequencies together
    By bobonapoletano in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 07:34
  5. Using Different Xtal Frequencies
    By bobsimpson in forum mel PIC BASIC Pro
    Last Post: - 20th July 2003, 21:36
