further testing showed that when sequences of commands to do read and writes over multi sectors , the the busy_chk routine requires to be checked not just for writes , but also for reads
if a read is done during a cycle of a sector erase,write , the read is not done at all
as such the code changed to
Code:Flash_Comand: ' assumes SDC_address long ' assumbe data_Length = Lookup table to fill ' max 256 bytes per write ' erase of the sector by byte / bulk is needed prior to write , as a write only changes a 1 to 0 , and the erase chanse the 0 to 1 if SDC_cmd = 0 then return ' invalid command if value =0 Lookup SDC_cmd,[$00,$01,$02,$D8,$C7,$B9,$9E,$03,$0B,$9F,$AB],SDC_CmdCode ' asignes command code to flash chip Flash_tmp = 0 ' ensure 0 - counter for busychk loop gosub BSY_chk ' do for all commands if SDC_cmd <=4 then ' do for writes, sector erase,bulk erase , write reg protect FLASH_CE = 0 ' Bring the FLASH chip select line low. SDC_data_out = Flash_Wr_en ' Send command byte that requires a write Gosub Flash_spiw ' Write Byte SDC_data_out. , subroutine writes a byte on the SPI bus FLASH_CE = 1 ' Bring the FLASH chip select line high to complete the write command pauseus 1 ' pause between prev command - may not need endif FLASH_CE = 0 ' Bring the FLASH chip select line high to complete the write command SDC_data_out = SDC_CmdCode ' Send the command byte, Gosub Flash_spiw ' Write Byte SDC_data_out. , subroutine writes a byte on the SPI bus if SDC_cmd =>2 and SDC_cmd <=3 or _ ' if commands 2= Page write 3= Sector Erase, SDC_cmd =>6 and SDC_cmd <=8 then ' or 6=Signature read( 3 dummybytes) 7= read data normalspeed or 8 read data at Highspeed then set given address SDC_data_out = SDC_address.Byte2 ' set sector Address 0 to 15 for 8mb chip Gosub Flash_spiw ' Write Byte SDC_data_out. SDC_data_out = SDC_address.Byte1 ' set page address 0 to 255 Gosub Flash_spiw ' Write Byte SDC_data_out. SDC_data_out = SDC_address.Byte0 ' set byte address 0 to 255 Gosub Flash_spiw ' Write Byte SDC_data_out. if SDC_cmd = 8 then ' read High speed mode SDC_data_out = $FF ' used as dummy byte for read High speed mode Gosub Flash_spiw ' Write Byte SDC_data_out. endif endif if SDC_cmd <=2 or _ ' if commands 1= write Register , 2= Page write , SDC_cmd >=6 and SDC_cmd <= 9 then ' or 6= read signature byte, 7=read data normalspeed, 8= read data at Highspeed , 9=read ID For SDC_index = 0 To Data_Length if SDC_cmd <= 2 then ' if write or Write register then SDC_data_out = SDC_buffer[SDC_index] ' send contents of indexed SDC_buffer gosub Flash_SPIw ' write byte SDC_data_in from SPI bus. Returns SDC_data_in. endif if SDC_cmd =>6 and SDC_cmd <=9 then ' if 6= read signature byte, 7=read data normalspeed, 8= read data at Highspeed , 9=read ID gosub Flash_SPIR ' Read Byte SDC_data_in from SPI bus. Returns SDC_data_in. SDC_buffer[SDC_index] = SDC_data_in endif Next SDC_index endif FLASH_CE = 1 ' Bring the FLASH chip select line high. return '---------------------------------------------------- Bsy_chk: FLASH_CE = 0 ' Bring the FLASH chip select line low SDC_data_out = Flash_Rd_reg ' Send the read status register command byte Gosub Flash_spiw ' Write Byte SDC_data_out. , subroutine writes a byte on the SPI bus Flash_tmp = 0 ' clear counter while Flash_tmp <150 ' loop test read gosub Flash_SPIR ' Read Byte SDC_data_in from SPI bus. Returns SDC_data_in. IF FLASH_Install = 1 then Flash_Reg_val = SDC_data_in ' get value of read status reg value for use in flash install program checks for protection HSEROUT ["STATUS REG = ",hex Flash_Reg_val,13,10] ' show on terminal when doing flash install HSEROUT ["Flash_tmp = ",dec2 Flash_tmp,13,10] endif Flash_tmp = Flash_tmp + 1 SDC_data_in = SDC_data_in & $01 if SDC_data_in = 0 then Flash_tmp = 151 ' Test bit 1 if write not busy,force exit of loop wend FLASH_CE = 1 ' Bring the FLASH chip select line high return
 Re: Spi flash chip example - 8mb flash
