Flash erase byte routine
Results 1 to 21 of 21
    Jun 2009
    Sc*nthorpe, UK
    Default Re: Flash erase byte routine
    Reading the data sheet and your code example makes me think this statement is not true.
    The FLASH as i have learned is not the same as EEProm in that you cant just change bytes values as you may like to on the fly , changing byte to $FF requires your do a complete sector erase , depending on the chip and the size the sector erase can range from 4k bytes to 64k bytes at a time.
    and a write to any location is possible. But I will keep reading
    Yes, they can be programmed one byte at the time at any arbitrary memory location. However, "programming" means changing (or not changing) a "1" to a "0". You can't change a "0" to a "1".
    So, before you can program a location it needs to be erased ("reset" to $FF). Erasing is done either sector by sector or the entire chip (bulk).
    Jun 2009
    Sc*nthorpe, UK
    Yes I understand now. I was having difficulty finding the write command in the data sheet but as you explained the program command is used.
  1. Erase error
    By waynepauly in forum mel PIC BASIC Pro
    Last Post: - 29th June 2012, 03:23
  2. Internal eeprom - erase block
    Last Post: - 13th February 2008, 12:11
  3. 18F2431 won't program or erase.
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 28th September 2006, 08:55
  4. 12F675 won't reprogram or erase
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 06:07
  5. 12F629 won't erase and bandgap save?
    By Keith55555 in forum mel PIC BASIC Pro
    Last Post: - 6th April 2004, 02:28
