I want to control the volume of the output using Sound command.
Results 1 to 12 of 12
    Default Re: I want to control the volume of the output using Sound command.
    I don't see the need for an interrupt for what you're doing there.
    X = 5
    Start:
       HPWM 3, X, 20000
       SOUND PortC.3, [255, 5]   ' Make sound for ~60ms
       X = X + 5
    Goto Start
    Though I'd probably setup the CCP module manually and write to the dutycycle register instead of using the HPWM command since I Believe you'll get some discontinuties in the output when constantly changing the dutycycle using HPWM - may be wrong on that and/or it may not matter in your case, try it.
    Nov 2013
    Totaly, i have tried all the methods you have suggested me, unfortunately the results wasn't so good.
    In every case, there was a small interrupt on the sound.
    I decided to produce the white noise by an external small circuit, and then to process it with PWM.
    Thank you all.
  1. pt2258+16f877 how can i use for 5.1 volume control ?
    By whyliving in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 18:51
  2. Volume Control On Piezo
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 13th August 2007, 05:34
  3. sound command
    By micro in forum General
    Last Post: - 1st April 2006, 19:09
  4. Volume Control IC's
    By HarryK in forum General
    Last Post: - 8th March 2005, 09:46
  5. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 15:08
