HMC5883L Magnetometer chip Possibilities.
Results 1 to 40 of 58
    Default Re: HMC5883L Magnetometer chip Possibilities.
    your degree calc is incorrect
    degr = brads*360/256
    this will overflow a word var causing errors
    degr = brads */ 360
    is the better way
    May 2012
    Merseyside, UK
    Hi Richard.
    Still reading between 100 to 900 on degrees.
    Close to the River Mersey in Liverpool here fireworks are all ready noisy
    Thank you for help ....
    looks like you are converting azimuth to degrees twice
    once here
     'Calculate Azimuth
      GOSUB GetAzimuth
      'Calculated Heading in Degrees
       brads = azimuth     'get angle
      'degr = brads */ 361 'convert to degrees
       degr = brads*360/256      and this is still wrong needs to be  degr = brads */ 360
       Lcdout $fe, $C0, "Degrees =",SDEC degr
    and once here
    x = readx >>4
    Y = readY >>4
    Z = readZ >>4
      'DEBUG       "SCALED X,Y", CR
      'DEBUG       "X = ",11, SDEC x, CR
      'DEBUG       "Y = ",11, SDEC y, CR
       'azimuth = x ATN -y
      azimuth = ( x ATN -y) */ 360
    surly once is enough
    azimuth = x ATN -y
  1. 3 axis digital compass sensor HMC5883L
    By ScaleRobotics in forum General
    Last Post: - 8th June 2014, 23:19
  2. How to use this IO chip?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 30th April 2013, 20:06
  3. compass chip
    Last Post: - 27th October 2009, 02:42
  4. Do you use ICD possibilities of MicroCode Studio
    By octal in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:22
  5. Which chip do i use?
    Last Post: - 2nd December 2007, 23:28
