HMC5883L Magnetometer chip Possibilities.
Results 1 to 40 of 58
Threaded View
  1. #18
    Default Re: HMC5883L Magnetometer chip Possibilities.
    But now the I2CRead command is failing on on the HIGHBYE and LOWBYTE locations, I think it due to the X declare beng a Byte now not a Word
    the i2c read uses the word var readingx the byte var x is the "scaled" result from that reading
    if you can't work that out post your code so we can see what your doing {in code tags }
  1. 3 axis digital compass sensor HMC5883L
    By ScaleRobotics in forum General
    Last Post: - 8th June 2014, 22:19
  2. How to use this IO chip?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 30th April 2013, 19:06
  3. compass chip
    Last Post: - 27th October 2009, 01:42
  4. Do you use ICD possibilities of MicroCode Studio
    By octal in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 17:22
  5. Which chip do i use?
    Last Post: - 2nd December 2007, 22:28
