Help in ASM code
Results 1 to 9 of 9
    Default Re: Help in ASM code
    Sotasota, There apears to be some code missing?
    EN82fn
    Wonder what's in here.
    #include <irmtxv4.inc>
    Ooops! Sorry, here is the missing code!! :-)
    ;    Filename:	    irmtxv4.inc                                       *
    ;    Notes:
    ; IR transmitter prot.v4 (Manchester)
    	EXTERN mtx_buffer, mtx_delay
    	EXTERN mtx_init, mtx_send
    And:
    ;    Filename:	    irmtxv4.asm                                       *
    ;    Notes:
    ; IR transmitter prot.v4.2 (Manchester)
    ; header : 20xbit1, 1xbit0
    ; bytes : 8xbitX, 1xbit1, 1xbit0
    ; packet structure: <data0> <data1> <data2> <checksum>
    ; 020 - library version
    ; untested!
    ; 021 - add half frame variable
    ;       remove buffer initialization
    ; 030-20050102 codec-v4.2:
    ;              checksum with CRC-8
    ;              T=350 usec
    ;              3-byte buffer length
    ; 031-20050227 same format for IR
    ; the TX output is fixed, it uses the hardware PWM output pin
    	list      p=16F684
    	#include <p16F684.inc>
    	GLOBAL mtx_buffer, mtx_init, mtx_send, mtx_delay
    packet_len	EQU 2
    pwm_freq	EQU d'38000'
    ;dc_value	EQU d'500000' / pwm_freq
    ;dc1b_value	EQU (d'2000000' / pwm_freq) - (4 * dc_value)
    ; rather use the exact period rate/2 for duty cycle calculation
    dc_value	EQU (d'1000000' / pwm_freq) >> 1
    dc1b_value	EQU ( (d'1000000' / pwm_freq) << 1) - (dc_value << 2)
    ccp1con_value	EQU (1<<CCP1M3) | (1<<CCP1M2) | (dc1b_value << 4)
    pr2_value	EQU (d'1000000' / pwm_freq) - 1
    ;***** VARIABLE DEFINITIONS
    mtxdata		UDATA
    count1		res 1
    count2		res 1
    ncnt		res 1
    bt		res 1
    sum		res 1
    mtx_buffer	res 2
    mtx_delay	res 1 ; half_frame delay
    mtx		CODE
    mtx_init
    		BANKSEL T2CON
    		movlw (1<<TMR2ON) | (0x00)
    		movwf T2CON ; TMR2 on, 1:1 prescaler
    		movlw dc_value
    		movwf CCPR1L ; PWM duty cycle
    		movlw 0 ; ccp1con_value
    		movwf CCP1CON ; turn off CCP module
    		BANKSEL PR2
    		movlw pr2_value
    		movwf PR2
    		BANKSEL PORTA
    		movlw .117 ; 350 usec
    		movwf mtx_delay
    mtx_send
    		; send out buffer
    outbuf		movlw 0x14 ; 20xbit1, 1xbit0
    header		movwf count2
    head0		call bit1
    		decfsz count2,F
    		goto head0
    		call bit0
    		movlw mtx_buffer
    		movwf FSR
    		movlw packet_len
    		movwf count1
    		movlw 0xff
    		movwf sum
    outbu0		movf INDF,W
    		call update_sum
    		movf INDF,W
    		call outbyte
    		incf FSR,F
    		decfsz count1,F
    		goto outbu0
    		movf sum,W
    		call outbyte
    		; buffer is sent
    update_sum	; fast CRC-8 algorithm with poly x^8+x^5+x^4+1
    		; executes in 23 cycles per update
    		xorwf	sum,f
    		clrw
    		btfsc	sum,7
    		xorlw	0x7a
    		btfsc	sum,6
    		xorlw	0x3d
    		btfsc	sum,5
    		xorlw	0x86
    		btfsc	sum,4
    		xorlw	0x43
    		btfsc	sum,3
    		xorlw	0xb9
    		btfsc	sum,2
    		xorlw	0xc4
    		btfsc	sum,1
    		xorlw	0x62
    		btfsc	sum,0
    		xorlw	0x31
    		movwf	sum
    outbyte		movwf bt
    		movlw 8
    		movwf count2
    outby0		rlf bt,F
    		btfsc STATUS,C
    		goto outby1
    		call bit0
    		goto outby2
    outby1		call bit1
    outby2		decfsz count2,F
    		goto outby0
    		call bit1
    		; and bit0
    bit0		movlw pr2_value-3
    		movwf TMR2
    		movlw ccp1con_value ; HIGH
    		movwf CCP1CON
    ndelaya0	movf mtx_delay, W
    		movwf ncnt
    ndelaya1	decfsz ncnt, F
    		goto ndelaya1
    		movlw 0 ; to LOW transition
    		movwf CCP1CON
    ndelayb0	movf mtx_delay, W
    		movwf ncnt
    ndelayb1	decfsz ncnt, F
    		goto ndelayb1
    bit1		movlw 0 ; LOW
    		movwf CCP1CON
    ndelayc0	movf mtx_delay, W
    		movwf ncnt
    ndelayc1	decfsz ncnt, F
    		goto ndelayc1
    		movlw pr2_value-3
    		movwf TMR2
    		movlw ccp1con_value ; to HIGH transition
    		movwf CCP1CON
    ndelaye0	movf mtx_delay, W
    		movwf ncnt
    ndelaye1	decfsz ncnt, F
    		goto ndelaye1
    The next step once this is figured out will see how I can use Pic Basic 3 to compile and make a HEX file so I can program the pic. I tried to compile already but got lots of errors. But, will cross that bridge later.... :-)
    Also SORRY for the multiple posts. I could not figure out how to delete the other post. Can you let me know how I delete posts? Thanks and my apologies. :-)
    Don't worry about double thread, it's closed and you didn't get any infraction. I just posted a "canned reply" that we have available.
    Post all your code using code tags in Advanced at bottom right. Also mention which PIC and assembler.
    Edit: oh yeah, and the errors!
    Thanks Robert! I still do not know how to delete a thread. :-)
    OK, as for the code, at this stage I need to figure out why a key-press only allows for a 1-2 second burst rather than continuous. Then, once that is figured out, I will then try to compile it. I am using PBP3 and EPIC USB programmer. Thanks!
    Quote Originally Posted by SOTASOTA View Post
    That is the job of MPASM. PBP accepts BASIC Mnemonics and creates the Assembly code, mpasm turns the assembly code into the intel hex, which you load into the PIC with your programmer. When you have set up MicroCode Studio correctly it becomes a 1 click operation, unless you have an error in your code or inadvertently choose the wrong PIC.
  1. am I being rude to ask this. . .ASM code request
    By camcompco in forum mel PIC BASIC Pro
    Last Post: - 11th March 2013, 12:54
  2. How Convert a Hex Code to a ASM???
    By jenny90 in forum mel PIC BASIC Pro
    Last Post: - 25th January 2011, 02:34
  3. ASM code
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2010, 00:55
  4. Adding PBPro code to an ASM file - how to?
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 19:49
  5. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 20:21
