Storing hours and minutes into single byte?
Results 1 to 17 of 17
    Default Re: Storing hours and minutes into single byte?
    Differentiation between 11:14 and 14:11 will be quite easy, because when time from RTC reaches that time, a variable is toggled, which can be later used to determine exactly what time should be read now.
    Feb 2011
    If you can live with 2 second resolution then there are 43200 2-seconds per day -- one word.
  1. SEROUT command (single byte value not string)
    Last Post: - 12th June 2010, 03:34
  2. 6 hours for a comma, a space, and some caps.....
    Last Post: - 13th March 2009, 20:31
  3. 10,20,30,40 minutes
    By helena in forum mel PIC BASIC Pro
    Last Post: - 1st March 2007, 12:04
  4. Timer and long (hours) sleep period - how to?
    Last Post: - 8th January 2007, 07:32
  5. increases every 5 minutes
    By Sasha in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2006, 21:09
