Subroutine or repeated code, which is more memory efficient?
Results 1 to 5 of 5
    Default Subroutine or repeated code, which is more memory efficient?
    I'm writing a program, where I have to use
    sound xma,[125,10]
    about 30 times. Should I make this as subroutine, will it be more space efficient, or compiler takes care of that?
    Default Re: Subroutine or repeated code, which is more memory efficient?
    Henrik could give more detailed answer, in the meantime...
    A loop of 2 or 3 is structured but not always smaller in code (especially when short like yours).
    But 30 times, I'd go with a loop.
    You can always compile both ways and check code size (Microcode Studio posts it at the bottom).
    Last edited by Demon; - 5th June 2014 at 19:14. Reason: compiler will not generate a loop for you, just repeat the instructions.
    What happend to simply trying a couple of things yourself and see instead of just asking. I just tried it here and it took less than five minutes to try both ways and write this reply.
    Same routine repeated 30 times: 458 bytes
    Subroutine and 30 GOSUBs: 201 bytes
    This was compiled for a 16F877A whcih is the device you had questions about the other day. And no, the compiler doesn't decide for you - it's up to you as the programmer.
    YAY! I guessed right!
    Thanks!
    I've tried to look at microcode studio displayed code size, but it does not seems to be in relation with actual code - I've added say 20 lines of new code, but sometimes size gets increased by only 1-2 words, sometimes - 200.
  1. Stopping repeated messages
    By GatorGuy in forum mel PIC BASIC Pro
    Last Post: - 20th October 2011, 20:40
  2. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 14:28
  3. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  4. Embedding Variables into Code Memory
    By JoeSolar in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 18:58
  5. fatal error [301] out of memory with 4 lines of code????
    By George in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 22:26
