Rechargeable Gel cell substitution
Results 1 to 12 of 12
    Default Re: Rechargeable Gel cell substitution
    if you can get the top off the battery could you scoop out the guts and stick a couple of lipo batteries in there , they are nomimaly 3.6v but read 4v + when fully charged
    They don't really have to fit back in the old battery case, I can tie-wrap them together and stuff them in the handle.
    I just have little to no battery experience and wasn't sure what types I can and cannot use in a gell cell application.
    Hi Robert, have you checked Mouser? http://www.mouser.com/Power/Batterie...5gbk?P=1z0wd7y
    Might have something useful.
    Quote Originally Posted by Archangel View Post
    Hadn't thought of them, just a tad too big.
    I hate our disposable retail industry, it costs more to buy a battery than a complete unit on special.
    I think these had cost $9.99 years ago.
    Dec 2010
    The gel cells are basically lead acid car batteries (in this case with 2 cells instead of the usual 6). In this application you can use pretty much anything that can supply lots of current for a long time.
    The tricky bit will be the charger. If the flashlights are the ones with a built in charger, and you want to use that charger, then you should stick to gel cells. If you are willing to charge them externally, you can use pretty much anything.
    Attempting to charge LiPo or even Nimh with a lead acid charger is likely to require a fire extinguisher, or even an ambulance.
    Jun 2009
    Sc*nthorpe, UK
    Check this site
    http://www.atbatt.com/batteries/agm-...?voltage2=3986
    looks like your picture.
    4v 1.5Ah is very small for lead acid!
    Quote Originally Posted by EarlyBird2 View Post
    Check this site
    Darn, just a tad too wide.
    This site didn't come up in my googling. I hate it that location plays such a huge part in search results.
    1.15" x 1.35" x 2.73"
    29mm x 34mm x 69mm
    I don't have a lot of room to work with.
    I suppose I can't even use old NiCD instead of SLA.
    Dec 2010
    It's hard to get to the correct voltage with NiCD or NimH - you end up with 3.6 or 4.8. If the charger is well designed it should be putting out 4.4, and constant voltage, where the NiCD or nimH want constant current.
    When you eventually find the right replacement battery, you will likely find it cheaper to buy another flashlight than a replacement battery - at least that was my experience.
    Comes of buying things on sale at CTC, I guess.
    I know and it sucks. I like these first-gen LED worklights and feel bad throwing away a perfectly good device.
    Quote Originally Posted by Charlie View Post
    Yup, the flashlight has a builtin charger circuit, I'd like to use that if possible.
    It's an LED flashlight, I find it very practical for playing pretend-mechanic.
    And that's why I'm asking here. Don't want to burn down my new garage.
  1. PIC16F876a and one lion cell
    By c2h5oh in forum General
    Last Post: - 1st October 2010, 09:31
  2. Save number cell in to EEprom
    By piombazzo in forum GSM
    Last Post: - 18th August 2008, 20:49
  3. schematic for rechargeable batteries
    By PoTeToJB in forum Schematics
    Last Post: - 11th May 2006, 17:36
  4. Replies: 1
    Last Post: - 20th December 2005, 03:56
  5. Cell Phone
    By elproducts in forum mel PIC BASIC Pro
    Last Post: - 6th October 2004, 01:21
