This jogged my memory regarding a problem I had regarding time of day comparisons. I had the idea of converting time of day to seconds into day which obviously could go up to 86400 and will not fit into a byte or word variable. I resolved the issue by comparing hours, minutes and seconds into the day which was just a few more lines of code.Speaking of which, I am having a problem there too. The elevation isn't an issue. From "stowed" (down) to full travel UP, is like 3665 pulses. But the azimuth is WAY more. From "stowed" around to physical limits one way is approx 220 deg, and 109300 pulses. And that's only partial rotation. Full rotation is about 400 - 450 deg, so I have a counter that needs headroom of about 250,000. What can i use that's bigger than WORD?
In your case is it possible to change pulses into second, minute and degree variables. Then again obviously your variables will have 60, 60 and 450. This will then be a clock routine of which there are many examples I am sure.
